Go to Post We are reluctant to deprive you of the experience of learning how to do your own research. - Alan Anderson [more]
Unread 28-01-2005, 12:17
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Using Extruded Aluminum to telescope.
We have done many arms using either nested Al tubing or monocoque. We make slide bearings out of HDPE tosit between the inner and outer arm. We also use window tape to run the arm in and out. Just a coup[le ideas to ponder...
Torsional Stiffness of Extruded Aluminum Ben Piecuch Technical Discussion 3 19-01-2005 21:55
where can I get info on extruded aluminum? SCYTE16 General Forum 21 13-01-2005 14:23
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
