Go to Post "How do we make our team be like your team?" That's the sort of question everyone should be asking of these so-called "elite" or "powerhouse" teams. - sanddrag [more]
Unread 20-01-2005, 19:09
LGuY LGuY is offline
LGuY is an unknown quantity at this point
Using Extruded Aluminum to telescope.
Hi, My team and I are interested in knowing how one would use extruded aluminum, since it is slotted, as a rail system for telescoping part of am arm. We purchased a kit that comes with 80' of the 3/4" material along with a bunch of small pieces used to connect them all but no manual whatsoever. The aluminum is from Item. Does Item make any piece that can freely slide along the slots in the aluminum for which a team can motorize and power? I tried searching myself but I turned up only more confusion, any help would be appreciated. Thank you!
Unread 20-01-2005, 19:17
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Re: Using Extruded Aluminum to telescope.
I know 80/20 sells linear bearings for their extrusion so they can freely slide past each other.
Unread 20-01-2005, 19:52
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I'd be surprised if they didn't include a catalog with your shipment. (especially that it is Item, those guys are really pushy salesmen) Regardless, you can go on their website www.itemamerica.com and find the linear bearings, rollers, whatever, that you need to make a linear slide.
Team 1257
Unread 20-01-2005, 22:01
Mohsin's Avatar
Mohsin Mohsin is offline
building...building...bui lding...
FRC #0772 (Club Sandwhich)
Mohsin is on a distinguished road
Send a message via MSN to Mohsin
A couple years ago we used plastic slides, with the aluminium, worked really good, with grease on it.
Unread 21-01-2005, 00:34
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
We have milled slides out of plastic-type material practically every year and it works great.
Unread 21-01-2005, 12:41
Lil_moe Lil_moe is offline
FRC #1031
Team Role: Operator
Lil_moe is infamous around these parts
I want to know where u purchased a rail system for telescoping from.
Unread 21-01-2005, 13:17
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
you can buy Delrin(sp?) sliders that is made specifically for Extrusions. They come in different profile. 115 used it for their 2003 robot to build an elevator.
Google "Bosch Rexroth"
check out their catalog. There are many other suppliers that sell extrusion materials, fasteners, linear motion etc..
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 25-01-2005, 01:59
VThokieME04 VThokieME04 is offline
FRC #1672
VThokieME04 is on a distinguished road
Send a message via AIM to VThokieME04
Team 401 did a great three segment telescoping mechanism that worked like a dream. I know this isn't the greatest picture in the world, but I'll see if I can't explain it and point you in the right direction.
In the dynamic elements section of the Item catalog are several different setups for roller guides. In order to make a telescoping mechanism you need several things: two or more pieces of extrusion to be used as your telescoping sections, shaft-clamps that fit whatever profile you're using (I'm assuming you're going with profile 5) and the shafts that fit in the shaft clamp profile. I know this is probably pretty confusing, but download the Item catalog and look at some of the pictures to match what I'm saying with the actual product.
Now last year was the first year I personally worked with Item and I was extremely impressed with their product line. If I can also throw in several suggestions. First, go with the adjustable roller bearings, part number 0.0.390.16 (assuming you're going with profile 5 extrusion). Buying the adjustable bearing unit allows you to get the right amount of pressure between the bearing and the rail that it guides on. You get less slop in your telescoping mechanism that way. Second, if you're short on weight don't buy the Item's shafts that clamp in the shaft-clamp profile. Instead, but stainless steel tubing from McMaster (5mm OD i believe, with the thickest wall available). This saved us an amazing 6 pounds last year, so it does add up. We didn't encounter any issues with binding or bearings seizing and it was probably the most robust part of our robot.
Here are two pictures that I have of the telescoping mechanism. If you'd like to see more, email me at jheaston@vt.edu
http://filebox.vt.edu/users/jheaston/FIRST/PICT0117.JPG
http://www.firstrobotics.net/04Galle...0401-1_jpg.htm
Unread 25-01-2005, 06:13
REVving up for a new season
FRC #2848 (All-sparks)
if you are thinking about this route check out team 340's bot from last year because they used extrusion with slides and a timing belt system to telescope
t
there are alot of good photos here http://robotphotos.org/2004-buckeye-340?page=1
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 25-01-2005, 08:16
jfischer's Avatar
jfischer jfischer is offline
AKA: Jerry Fischer
None #0056 (ROBBE Xtreme)
jfischer will become famous soon enough
Team 56 used extruded aluminum and sliders from 80/20 to build their elevator for last year. We used a chain drive with the van door motor, and had enough power to lift our robot on the bar. See the attached pictures.
Name:	Team 56 El-1.JPG
ID:	2837  Click image for larger version
Name:	Team 56 El-2.JPG
Unread 25-01-2005, 09:44
Small Parts sells aluminum tubing in graduated sizes that are intended to fit inside one another. You will still have the problem of how to get a lift to work with the small tolerance between sizes.
Be careful when purchasing off the shelf aluminum tubing, it may not be extruded. This tubing although theoretically able to nest inside each other, has some added material on the inside that prevents the tubing from sliding inside a larger piece. (This experience comes from trying to build vertical antennas out of tubes that start at max diamter of 1-1/2"' and go down from there.)
Unread 28-01-2005, 08:58
WizardOfAz's Avatar
WizardOfAz WizardOfAz is offline
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
WizardOfAz will become famous soon enough
Send a message via AIM to WizardOfAz
Hi Al
You mentioned experience building vertical antennas - knew you must be an amateur radio op. I'm Bill Bennett, N7DZ, licensed since '68, originally WB8ALU in Cincinnati.
This is my third year with Team 1011 in Tucson. We're working on a telescoping arm design using a 2.5 x 1.25 tube inside a 3 x 1.75 tube. Plan to only have rollers at the bottom outside of the inner tube and the top inside of the outer tube. Have never done any kind of telescoping arm before, so we're out on thin ice here....
Also working on a design to PUSH the telescoping section, and a sliding apparatus inside it, up from the bottom using spring steel push tape, along the same idea as electrician's fish tape. No cables or chains. Hope we can get it to work...
Any comments or suggestions about this from Al or anybody would be welcomed.
Bill
Unread 28-01-2005, 09:36
Originally Posted by WizardOfAz
Hi Al
Bill
Welcome aboard, Bill, de WB9UVJ (usually /9 or /0)
Your roller idea should work but I have noticed that rollers bind with a little dirt in the path and stop rolling. Sliding delrin or nylon followers work but need some lube to keep them happy. It will be interesting to see how your tape idea works, the tetras are heavier than they look. We have used "spectra" cable (a nylon string stronger than steel, available from McMaster) and a couple of pulleys coupled to a two sided drum. The motor pulls down in one direction and pulls up in the other direction. A silicone super glide spray works for lube. Don't forget a couple of microswitches back to digital inputs on the RC to prevent over travel. (backed up by mechanical stops. back up the backup)
QTH 25mi. NW of Chicago-- licensed in '76, now an Extra--wthr hr cold abt 6 this am--cul--
73
Unread 28-01-2005, 12:17
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We have done many arms using either nested Al tubing or monocoque. We make slide bearings out of HDPE tosit between the inner and outer arm. We also use window tape to run the arm in and out. Just a coup[le ideas to ponder...
Unread 29-01-2005, 18:06
cnield's Avatar
cnield cnield is offline
#1318 (Issaquah Robotics Society)
cnield is an unknown quantity at this point
Our team used telescoping extruded aluminium last year to get the hook up to the bar. It seemed to work well.
Never fight an inanimate object.
-P.J. O'Rourke
Torsional Stiffness of Extruded Aluminum Ben Piecuch Technical Discussion 3 19-01-2005 21:55
where can I get info on extruded aluminum? SCYTE16 General Forum 21 13-01-2005 14:23
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
