Go to Post Good engineering involves working with constraints, not complaining about them. - Norman J [more]
Unread 28-01-2005, 09:46
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Victor Muffin Fans - Height Clearance?
Hey all,
I'm wondering what's the least amount of space you can have above the Victor muffin fans?
As usual, we're running tight on space with our electronics, and it looks like we can't leave any more than 1/2" of space above those fans.
Anyone cut it this close before? In the past, we've left at least 2-3" above the fans.
-SlimBoJones...
Unread 28-01-2005, 10:23
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Victor Muffin Fans - Height Clearance?
I dont believe that there is any 'minimum' amount of space persay, just keep in mind that you do want their to be sufficent air flow going to and from the victors, i am assuming your refering to the muffin fans on the victors. I have cut it close in the past, probably around 1/2" but i dont know if i would recommend it again, with that sort of clearance you run into other problems other then just air flow, like the amount of effort/time it takes to access things and change out parts, tighten connections, change connections, running wires, these sort of things are also things you want to consider when determining the amount of clearance around components.
But to answer your question more directly... as long as there is sufficent air flow, and the components wont over heat, i'd say 1/2" is fine, but not ideal.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 28-01-2005, 13:22
Andy A. Andy A. is offline
Getting old
FRC #0095
Slimbo-
Half an inch is plenty. The truth is that our Victors only rarely get hot enough to warrant the use of the fan. By the end of the match, I suspect that Victors running drive motors with out fans would be a little toasty, but probably not near failure. This is a bit like the case of putting heatsinks on motors- it helps in the long term, but over a two minute match, it's not really effective. Cooling the Victors shouldn't be a huge factor for us, as long as the fans are running, the Victors will be more then adequately cooled (which is why they are there- so you don't have to ever worry about them overheating do to poor airflow).
Bigger considerations in my mind with a tight clearance like that is going to be accessibility and visibility.
Unread 28-01-2005, 13:48
Originally Posted by SlimBoJones
Hey all,
-SlimBoJones...
Shawn,
1/2" should be OK if the controllers are not close to each other. If they are packed in tight you might want a little more than that. Remember that if they are too close, then the air the fan pulls through for cooling is actually it's own heated air coming back. Like recirculate on your car, the air just gets hotter and hotter.
Unread 28-01-2005, 15:32
AKA: Mr. Lim
Thanks for the responses all!
There is plenty of free space around the Victors, just not right above them =). We should be okay since there is opportunity for cool air to come in from the sides.
The points made about accessibility are well taken. I know it sounds crazy, but the reason we're making the clearance so small is in an effort to make everything much easier to get to .
Hopefully we'll have some pics of Team188's finished 2005 electronics board early next week!
-SlimBoJones...
Questions on Muffin Fans sanddrag Electrical 6 22-01-2005 10:57
NBA or WWE you decide... Kyle Love Chit-Chat 62 24-11-2004 09:15
Muffin fans .. Mike Hendricks Electrical 4 19-02-2004 19:26
Dimension Wanted - BOM Caster: floor to top plate surface height kmcclary Kit & Additional Hardware 2 28-01-2004 12:02
GO Marlins! Tytus Gerrish Chit-Chat 26 17-10-2003 20:44
