Re: Globe motor mounting
I always thought a broach was something you used to finish what was already roughed in. (i.e. an edm or wire operation needs to be finished with a broach to make it smooth and accurate.) Any professional machine ops out there to answer?
hey I was just wondering, how, exactly, did you guys get the sprocket to fit with the globe motors, like did you guys use hub or hubless sprockets? Thanks.
I used the globe motor like a lathe and turned it down... Hooked it up to a 12V, put the gearhead in a vice, and held a file against it. It fits an FP pinion now, but sadly its too small due to some smoothing files that probably shouldn't have been made. Epoxy stripped twice, what do you think about JB weld on the armature? Would it hold? I cant see easily putting a pin into the FP gear without screwing up some teeth bigtime.
| 2 Globe Motors??? | ChuckDickerson | Motors | 18 | 25-01-2005 15:53 |
| Globe motor backdrive!! | Srkasner | Motors | 19 | 08-03-2004 00:10 |
| Globe Motor | archiver | 2000 | 4 | 24-06-2002 00:15 |
| So you want to stall a Globe Motor... | archiver | 2000 | 1 | 24-06-2002 00:09 |
| Globe Motors & other FIRST Suppliers at Design Show | archiver | 1999 | 2 | 23-06-2002 22:07 |
