Go to Post No caffine for you! - Koko Ed [more]
Unread 28-01-2005, 15:25
Re: Modifying CIMs to implode?
Originally Posted by Andrew Schuetze
I am not going to test the rule or disrespect the advice of motor techs on this list. My follow up is in regards to the reported gain in radiational cooling by removing the black paint by sanding to the bare metal?
Our team has never modified a motor or mount but the comment about bare metal verses paint is of mild interest. Does this violate the rule or even the spirit of the rule? I would guess that one could even add paint to the housing as part of some color scheme on the robot...
Andrew,
I think the rule is clear that removing the paint does not change the basic ops of the motor. But like I have said many times before, if the Chalupas (or any motor) are overheating they are a symptom not a cause. Hot motors indicate a problem somewhere else. Fix the problem. When the case of the Chalupa is hot, think what the temp might be inside at wire level.
When the case is too hot to touch, you have already sacrificed molten varnish to the electrical gods. There is no coming back from this abuse and no amount of external cooling is going to save the motor. The internal temperatures, melt the varnish insulation, run the lubricant out of the bearings, distort the armature plates and shaft, and breakdown the internal adhesives used to keep all the parts in alignment. Remember that the only conduction path from armature to outside world is the shaft and bearings. All other cooling is by convection or radiation which is a slow process.
Anyone modifying the stock gearboxes? Swampdude Technical Discussion 17 04-02-2005 13:15
Modifying Default code great_one411 Programming 7 16-02-2004 10:32
where to buy cims Brawler006 Motors 2 26-01-2004 13:16
Gears for CIMs Brawler006 Motors 5 18-01-2004 09:46
modifying sprockets gail OCCRA 3 05-10-2002 12:13
