Go to Post Holonomic? I thought we were holographic. Or was that autonomic? I'm confused.... - Wayne C. [more]
Unread 28-01-2005, 17:06
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
7.2 Volt Battery
We are trying to find spare 7.2 Volt batteries. Is it against the rules to use outside 7.2 volt batteries? We cant find any through first. Thanks
Justin
Team 302
Unread 28-01-2005, 17:10
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: 7.2 Volt Battery
No you can use any 7.2 volt 700mA NiCd battery that you can fit to the proper connectors. Though you can buy them for $15 through IFI at http://www.ifirobotics.com/edu-electrical.shtml
-Michael Dessingue
Unread 28-01-2005, 17:49
Justin_302's Avatar
Justin
AKA: Justin
Team Role: Driver
thanks
Team 302
Unread 28-01-2005, 23:10
Andy A. Andy A. is offline
Getting old
FRC #0095
More accurately, you can use _any_ 7.2 volt NiCad battery pack. This means that if you wanted to, you could just a much higher capacity pack. You are not limited to 700mAh. While we aren't opting for it, it would probably be useful if you plan on testing with your camera system a lot. I have happen to have a 3300mAh pack, which I think is about the highest capacity you can readily find. The drawback is a higher weight penalty. I can imagine having a high capacity battery for nonmatch work, and the lighter kit supplied pack for matches.
Check out hobby shops, 7.2v packs are a standered among R/C cars. A car sized pack will cost you around 20 dollars from a shop, depending on the capacity and quality. You can find them cheaper online if you don't mind waiting a while to get it and using generic brands.
-Andy A.
Unread 28-01-2005, 23:25
You can order a battery pack from Digikey in any configuration and any amp/hr you choose.
Battery Charging Box MikeDubreuil Electrical 17 22-04-2004 21:38
Charged 7.2 battery Daniel Brim Electrical 2 01-02-2004 10:46
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
