Re: Modifying CIMs to implode?
Originally Posted by Al Skierkiewicz
Andrew,
I think the rule is clear that removing the paint does not change the basic ops of the motor. But like I have said many times before, if the Chalupas (or any motor) are overheating they are a symptom not a cause. Hot motors indicate a problem somewhere else. Fix the problem. When the case of the Chalupa is hot, think what the temp might be inside at wire level.
When the case is too hot to touch, you have already sacrificed molten varnish to the electrical gods. There is no coming back from this abuse and no amount of external cooling is going to save the motor. The internal temperatures, melt the varnish insulation, run the lubricant out of the bearings, distort the armature plates and shaft, and breakdown the internal adhesives used to keep all the parts in alignment. Remember that the only conduction path from armature to outside world is the shaft and bearings. All other cooling is by convection or radiation which is a slow process.
i know this is off topic, but last year we had drill motors running to a custom gear box (like many other teams). After each round we had 2 of the 120mm fans blowing on the motors because they were almost too hot to touch. My question is, are the CIM motors as likly to get that hot? We are currently being held up by electronics problems, and we have no way to run one for 3 minutes and take the temp. Sorry if that was confusing, i know it was poorly worded.
TIA
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
