Go to Post Only Dave knows [if the 2010 game is designed already], and he aint tellin' but he'll happily feed you lots of red herrings. - Koko Ed [more]
Unread 28-01-2005, 20:12
S.Nickens's Avatar
S.Nickens S.Nickens is offline
Morpheus
#0011 (M.O.R.T.)
S.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to all
Re: Keeping the Chuck on the mill
Originally Posted by phrontist
We've got a rong-fu mill (purchased on the reccomendation of Mr. Lavery) and we're delighted with it. Save for one thing. It seems that no matter what speed we set it to, how fast or deep we cut, its only a matter of time until the chuck falls off, damaging our work and (once or twice) the table. The chuck, accoording to the manufacturer we just have to hammer it on the tapered drive shaft, but despite doing this really hard (and using an air-hammer to really drive it up there) it continues to fail. How do other teams deal with this. Why don't they have a screw or something to keep the chuck on?!
Any help would be greatly appreciated!
The problem you're having is related to whats known a "morse taper". A Morse taper is a standerdized locking taper, two shallow angle tapers, male and female, that when pressed together form a very strong lock.
There are standards to morse tapaers and they are gaged by size, #1, #2, #3, and so on. The taper ( angle ) on the R-8 Jacobs Chuck arbor (The part that mounts in the mill) or the drill chuck itself is damaged or out of spec..
An inexpensive solution is to try and claen up the tapers. You can use a polishing stone to smooth the surface of the arbor. Polishing stones are similar to sharpening stones. They're like hard pieces of fine sandpaper.
I would recommend something between 220 and 400 grit 1/4" x 1/4" x 6". You can get them at McMaster Carr for a couple of bucks. While the chuck is off the arbor, turn the machine on to a moderate speed (approx. 800 RPM) and
stone the taper of the arbor to remove any high spots. Move the stone up and down the taper keeping the stone flat. Next, clean the internal taper of the chuck. Stick the corner of a towel or rag in the taper while twisting
and pushing. Make sure both tapers are clean, put them together and give them one good solid hit. If this doesn't
fix the problem you may need to buy a new arbor or chuck, or both. An arbor will run you about $45 and a chuck can run you between $45 and $100 so you'll probably want to try and fix the one you've got.
Let me Know how you make out. Good Luck.
If you think you can, or if you think you can't, you're probably right.
2005 Palmetto AutoDesk Award
2005 Palmetto Judges Award
2005 Palmetto Semi-Finalists
2005 NJ Regional Chairmans Award
2005 NJ Regional Finalists
2004 Curie Div. 5th Seed
2004 Palmetto Regional Winners
2004 Palmetto DC Team Spirit Award
2004 Chesapeke Semi-Finalists
2004 Trenton Semi-Finalists
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Mill Suggestions? phrontist General Forum 29 27-02-2005 14:00
CNC Mill Help Rickertsen2 Technical Discussion 8 25-08-2004 00:59
Haas CNC Mill Graph Function P-Dog Technical Discussion 9 13-03-2004 23:45
1/2" #20 threads keyless chuck needed Jeff Frangenber Motors 3 13-02-2004 07:54
