Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Unread 28-01-2005, 22:37
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Connecting Switch to RC
Originally Posted by Mr. Steve
Does anybody have any information regarding hooking a switch (ex: Radio Shack #275-663)directly to the robot controller. I notice that switch has 3 pins, but I'm not sure which wire would go to which. What about if the switch/button only has two wires? Where would the ground go?
You are correct in assuming that the switch has to be connected to the digital inputs on the RC.
The three switches are for the 2 positions and the ground.
I will try to make a picture:
Pins
Connection
There are 2 positives because there is 2 positions and either one can be on, while one is on the other will be off.
Check the documentation for more specifics on wiring them.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
Digital Inputs interfering with each other Bongle Programming 8 23-02-2004 11:18
OI jog switch Natedude Control System 4 22-02-2004 17:13
connecting pressure switch kingpin3787 Pneumatics 2 19-02-2004 21:01
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
