Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Unread 28-01-2005, 23:30
S.Nickens's Avatar
S.Nickens S.Nickens is offline
Morpheus
#0011 (M.O.R.T.)
S.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to all
Re: Modifying CIMs to implode?
Originally Posted by Cory
I think you mean high... if your robot is geared low, it would mean it's very slow, which means it's harder to stall the motors, which creates heat.
Or maybe I interpreted what you're saying entirely backwards
I'm sorry if I mis-spoke regarding the gearing being too high /low. What I was trying to say is, if you gear your drive train to run the motors at max. RPM they are less likely to overheat because they are under less load. We competed in three regionals and the nat's and never once had a heat problem with the CIM"s Just trying to be helpful, nothing else.
Good Luck!
If you think you can, or if you think you can't, you're probably right.
2005 Palmetto AutoDesk Award
2005 Palmetto Judges Award
2005 Palmetto Semi-Finalists
2005 NJ Regional Chairmans Award
2005 NJ Regional Finalists
2004 Curie Div. 5th Seed
2004 Palmetto Regional Winners
2004 Palmetto DC Team Spirit Award
2004 Chesapeke Semi-Finalists
2004 Trenton Semi-Finalists
Anyone modifying the stock gearboxes? Swampdude Technical Discussion 17 04-02-2005 13:15
Modifying Default code great_one411 Programming 7 16-02-2004 10:32
where to buy cims Brawler006 Motors 2 26-01-2004 13:16
Gears for CIMs Brawler006 Motors 5 18-01-2004 09:46
modifying sprockets gail OCCRA 3 05-10-2002 12:13
