Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Unread 28-01-2005, 23:31
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Drivers
one or two drivers of the bot this year
every year for the past 4 years we have had two drivers but this year some seniors want to just have one driver for both buttons and stick
what is your team doing?
Unread 28-01-2005, 23:36
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Drivers
It depends on the robot.
If your robot doesn't have any arms or lifts, or manipulators, it may be better to have only one driver. This way they have control of everything they need to do.
If you have something other than a basic drive platform, and your robot has too many functions for one person, then you should use 2 drivers.
Basically, if one person can handle the whole robot well, then you can use one driver.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 28-01-2005, 23:48
JulieB's Avatar
well........
AKA: Just Julie!
FRC #0538
Re: Drivers
only bad thing about one driver what if that person freezes on the field know one else can touch the controls
~julie
Unread 28-01-2005, 23:50
Re: Drivers
Originally Posted by JulieB
only bad thing about one driver what if that person freeze on the field no else can touch the controls
~julie
That's why you have driver tryouts. To pick the best driver.
Also, please use punctuation.
155, teacher: 2011-
Unread 28-01-2005, 23:56
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Drivers
~julie
Not quite true. You can have two drivers on the field, even if only one is required to run the robot. If you can get away with one driver operating all the functions of the bot, I would highly encourage you use the second driver position as an additional coach. Having another set of eyes on the team that doesn't have to worry about the 'bot every second is another set of eyes that may see the golden opportunity. Both drivers can 'tag team' the controls if you wish, switching positions.
This is fairly critical this year, as the human player is isolated from the rest of the team, and won't be able to communicate effectively. The load on the coach has gone up because of this.
But, I do caution against putting all the bot functions on one person. accurately moving a robot on a small field crowded with 5 other robots, goals and tetras is challenging. If the driver then also has to keep track of a box of switches, things can get pretty complicated fast. It has been done, but I think that when it works is a combination of good controls, simple bot functions and a superb driver.
-Andy A.
Unread 29-01-2005, 00:02
JulieB's Avatar
well........
AKA: Just Julie!
FRC #0538
Re: Drivers
-Andy A.
this years drivers are going have to very good at talking and listen
Unread 29-01-2005, 11:51
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Drivers
I think its better to have two drivers for a few reasons:
  1. Easier for each driver to control specific functions.
  2. The drive only has to worry about moving, and colliding with other robots - if they're trying to move the arm, they can't do that.
  3. It gives a chance for more members to actively participate during the competition.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 29-01-2005, 13:44
melmo's Avatar
melmo melmo is offline
AKA: matt
#0365 (MOE)
Team Role: Driver
melmo is on a distinguished road
Re: Drivers
In past years we have one driver directing the chassis and another driver controlling all the accessories. The same will probably hold true for this year
Unread 29-01-2005, 14:03
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Drivers
If you have any sort of endefector... you almost always have to have 2 drivers. The base driver must be solely concentrated on moving your bot by the other 5 bots and 9 goals on the field.
I also dislike the idea of two coaches. One coach is the brain of the team. He communicates with the other 2 coaches and his 2 drivers. The only thing another coach would do is cause confusion IMHO. If a only a single driver is required, have the second person available shout out time intervals.. or interpret the coaches directions to the driver. 2 thinking decision making coaches is bad. The strategy must come from one source period.I am not saying that a second person couldn't be used.. timing and robot alerts are great uses. But it is much much much easier when there are 2 drivers for a robot that has a manipulator of any kind. The drivers are just the hands on the floor implementing what the coach says.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 29-01-2005, 14:19
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Re: Drivers
If you don't have an arm, you can still use the operator as a second coach. The operator could be the person talking to the human player or keeping an extra eye on the field. Even if you don't plan on using the operator to actually operate, you can still use them for other reasons.
GO 1403!!!
Unread 29-01-2005, 14:27
Corey Balint Corey Balint is offline
Now comes without cockiness.
AKA: Corn Dog
FRC #0125
Corey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond repute
Send a message via AIM to Corey Balint
Re: Drivers
In 2003, we only had one driver, and look where it got us, National Finals. It really depends on the robot and the driver though. If you have new driver/not to great a driver, it is obviously best to have two drivers out on the field. But in 2003, we had a 3 year driver out there doing the rounds by himself, flawlessy might i add.
A few things i can think of for not having 2 drivers:
1. Less communication for the coach to do.
2. Time between switching objectives can decrease.
3. Two coaches
4. (i have more, however i am drawing a big blank right now)
I know however, all my points can be countered, so it really just depends on the strength of the driver and the strength/diffuculty of the bot.
BTW-I personally think having 2 coaches can be very beneficial this year. You can have one talk to each alliance partner, and each can be watching separate tasks.
Don't be scared to post something that is more than "dave is great" "here's my caption contest entry" and "overdrive is the best thing ever". Say something interesting. Say something that will make others think. Create discussion.
If you do say something that isn't just for fun or praising something, which hopefully you do, just be prepared to back up what you said.
Remember: GP is Gracious Professionalism, not Glorifiying Plesantries. Saying something negative does not mean you are evil. It could help someone out a lot.
Anything that I post is an opinion from my own mind. Some may agree with it, others may not. However do not negatively associate anyone else, including any team I work with, with my opinion.
Unread 29-01-2005, 19:08
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: Drivers
As always...45 will have one driver and one operator. Both of the positions are still unfilled at this time since we haven't had try outs yet. What other team(s) have driver/operator tryouts?
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 29-01-2005, 20:25
Charley's Avatar
Charley Charley is offline
Alumnae, Capt v2 for ever.
None #1350
Charley is on a distinguished road
Send a message via AIM to Charley
Re: Drivers
Last year was our rookie year, and before we even started on the bot, we had a student who decided to bring in his RC cars.
It was pretty clear who the best driver was going to be. Every once and a while other people drive it, but he is our main (and only) competition driver.
He's very good with using controls, and it is better for him personally to have them at the same time, but it all depends on the team. In our team, I don't think people communicate well, and it'd be hard for more than one driver to control, or even to switch coaches from match to match.
Unread 30-01-2005, 00:10
JulieB's Avatar
well........
AKA: Just Julie!
FRC #0538
Re: Drivers
Yeah! on the coaches thing they cant work together in one mind set.
Unread 30-01-2005, 00:14
Bharat Nain's Avatar
Re: Drivers
I disagree. If you split responsibilities you can definitely work together. Playing the game should be one coach's job. Maybe something like watching the time. In this years game you could probably use another coach for watching the goals capped and stuff? If you work it out right you can do well. That's a guarantee. It worked well for us in 2003. We were the CMP finalist.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
East Coast Drivers Union Corey Balint FIRST-related Organizations 153 10-04-2006 15:50
[OCCRA]: OCCRA Drivers Alex Golec OCCRA 4 13-01-2005 19:03
Writing Drivers For ide devices datatab1 Programming 4 20-09-2004 11:05
Operator Interface LED Drivers Andrew Programming 7 15-03-2004 11:27
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
