Go to Post Fun is not where you find it but where you make it. - Foster [more]
Unread 29-01-2005, 01:28
Skiguy523 Skiguy523 is offline
Capt. Team 1182
AKA: Peter Maginot
#1182 (Patriots)
Team Role: Operator
Skiguy523 is an unknown quantity at this point
Send a message via AIM to Skiguy523
BAFO USB to 9 Pin Adapter
So we finally got our BAFO adapter in, in hopes of getting reasonably quick download times. Just one problem. IT WONT INSTALL! Windows (XP SP2) recognizes the deivce immediately upon plug in, but instead of starting the new hardware wizard as per the included instruction manual, and using the driver off the CD-ROM, windows just installs no drivers, and does npot allow any drivers to be installed for the "Unknown Device", saying that even when I specifically select the correct driver "Driver does not contain info about the unknown device". What to do, what to do?
Unread 29-01-2005, 01:44
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: BAFO USB to 9 Pin Adapter
What are you plugging the USB adapter into? Is it a desktop or a laptop, and if a desktop, a front USB or rear USB port?
The only way a USB device will show up as an Unknown Device is if the device is defective, or one of the USB connectors on the computer is bad (either a bad contact, or if part of a bracket or front USB some of the pin headers may not be connected properly). Try the adapter on another USB port (preferably rear connector attached to the motherboard), or another computer and see if it works- if it does, you have a bad USB connection. If it does not, you have a bad adapter.
Unread 29-01-2005, 01:49
D.J. Fluck
Posts: n/a
Or there is a driver the computer lacks....then windows automatically assumes its defective...
http://www.bafo.com/bafo/drivers/BF-...2303_v1500.zip
Heres the updated driver for the device...im assuming you have the BF-810
hope this helps
USB Joystick to DB15 team1307 Control System 7 21-01-2005 11:58
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
4 pin EDU PWM out power, red pin2 V in error Dale(294engr] Electrical 4 13-02-2004 03:03
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
PBASIC access to 1 pin only diego25 Programming 13 21-01-2002 10:55
