Go to Post So perhaps those that are so eager to complain might realize that if they spent a little less time complaining and a little more time analyzing the problem and developing solutions, then they might have a little less to complain about. - dlavery [more]
Unread 29-01-2005, 11:10
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Quick 3ds max problm and question
In 3ds max when I want to move/scale/rotate an object none of the "arrows" are there to grab. I must have accidentally changed something. Could someone help me please? This is critical.
Thanks,
Budda
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 29-01-2005, 12:35
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: Quick 3ds max problm and question
Go to customize on the menu bar, then preferences, then click on the Gizmos tab and make sure the box that in the top left hand side that says "on" is checked.
Eric
Unread 29-01-2005, 14:01
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Thanks.
Do The Tyler!
Unread 30-01-2005, 17:09
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Huh... now that I've got that fixed I found another problem. I might as well make this my official 3ds max problem thread.
Here it is...
When animation our robot, the mast and arm totally disappear somehow, or they randomly move to different places. This has caused me much frustration as I have been working on this problem since 10 am. I need some help on this. I want the mast to go up and then rotate then go back down again but I just don't know how to fix this problem it is so annoying.
Thanks in advance,
Budda
Do The Tyler!
Unread 31-01-2005, 19:48
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
You may have SNAPs on; you can turn it off by pressing the default shortcut 'S'. If that doesn't fix the problem, you can try re-centering the pivot, which can be done by going to the Hierarchy Tab > Affect Pivot Only > Center to Object. Or Reset Pivot.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 31-01-2005, 21:50
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
One mistake I make is that I move an object while the animate, or auto key (depending on the version), button is on when I don't want to animate it. If you select an object, you can see the 'keys' on the time slider. By right clicking on them, you can see what they are changing. You can move them and delete them as you want. Still not working right, there should be an animation curve editor tab near the time slider. Open that and select you part from the long list. There should be X,Y,Z and rotation lines. Select the offending movement and adjust the curve accordingly. Though, getting it right this way is hard. Try the other ways first.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
