Go to Post CAD is the oxygen for engineering. - Bharat Nain [more]
Unread 22-01-2005, 14:24
sojouner06's Avatar
sojouner06 sojouner06 is offline
None #0294 (Beach Cities Robotics)
Team Role: Student
sojouner06 has a spectacular aura aboutsojouner06 has a spectacular aura about
Send a message via Yahoo to sojouner06
My computer won't go online -- help! (was: ehh...)
i cant get one of the computers in our shop to go online properly. The cable is new, connection propper, and any hardware problem you can think of has been checked. I reinstalled the driver so i dont think that is the problem. It cannot ping. The network adapter, a '3com EtherLink 10/100 PCI For Complete PC Management NIC (3c905C-TX) #2' just wont start!
Yeah I know... , This is the real world...
Pardon; the grammar, problem?
Unread 22-01-2005, 16:07
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Exclamation Re: ehh...
Without actually knowing the system, or working on the system. Just a few things:
1. Is this a new NIC card? Just unpackaged, recently unpackaged, etc? Or is it used, or from another system, etc? It could just be a "dud".
2. Do you have another PCI I slot open on the mobo to test it in? Try loading it in another PCI slot on the computer, re-load drivers, and re-do testing that you have done and see where it takes you.
3. Have you tested it on another system? Are you unsure if it will work on any system? This could be the final test to see if it is a "dud" or not.
4. Check the website of the distributor (maker of the NIC card) for updated drivers, software, patches, etc.
[edit] 5. Check device manager to make sure the device is recognized, and not disabled (i.e. is enabled). [/edit]
Unread 22-01-2005, 17:32
sojouner06's Avatar
Team Role: Student
Re: ehh...
fully upgraded and PCI swaped but no results
I just dont get it, i tried fixing this for the whole day and cant get any internet, i guess it is the haunted computer
Unread 22-01-2005, 18:33
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: ehh...
For reference, you should also try to make your thread titles more descriptive. Something like "My computer won't go online" or, even better, "Network Adapter Problem" would be much preferred to "ehh...". It's hard to get people to notice your problem when they don't know what the thread is about.
Jeff Waegelin
Unread 22-01-2005, 18:52
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: ehh...
How does your computer get assigned an IP address? Via DHCP? If so, that may be the problem.. might try to open up cmd.exe and run this:
ipconfig /release all
ipconfig /renew all
That should get you an IP address if you're using DHCP. If you're on a network, and that ipconfig stuff doesn't work, try manually assigning an IP address. Find the IP of another computer on the network (run ipconfig /all on the other computer and it'll be in there) then change the last number. I don't really remember how to set an IP manually in XP, but it's somewhere around in network devices or something. Once you get the IP manually set, try pinging the other computer's IP address. Since I don't really know how you're connected to your network and am doing all this from memory, that's the best advice I can give you.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 25-01-2005, 16:00
fancy013's Avatar
fancy013 fancy013 is offline
Memories to keep...
AKA: Fancy
None #0047 (Chief Delphi)
Team Role: Student
fancy013 will become famous soon enoughfancy013 will become famous soon enough
Send a message via AIM to fancy013 Send a message via MSN to fancy013 Send a message via Yahoo to fancy013
Re: ehh...
Uhm....? I don't know what to do either, but I hope you do!
mz.Fancy_ness(=purple, also color of love...)
Unread 29-01-2005, 13:01
Blues's Avatar
Blues Blues is offline
Neurotic newbie
AKA: Geoff Bell
#1633 (Robobuff1.0)
Blues is an unknown quantity at this point
Re: My computer won't go online -- help! (was: ehh...)
The other computers in your shop can go online, yes?
(May seem like a stupid question, but most of the computer problems in our school are the network's fault...)
Unread 29-01-2005, 14:46
sojouner06's Avatar
Team Role: Student
yes, all the other computers can go online
and, doing the IP address thing didnt work either because even though it got me to talk to other computers, it still could not get me to the internet
Unread 29-01-2005, 16:59
evulish's Avatar
1010100
AKA: Grant Harding
Can you ping 216.109.112.135? (Open cmd.exe, type: ping 216.109.112.135) It should return results with something somewhat similar to: 64 bytes from 216.109.112.135: icmp_seq=0 ttl=50 time=109.693 ms. If you can, try running: ping www.sandwich.com and see if that returns the same thing. If the first works and the second doesn't, you've got a problem with your nameservers. If neither of them work, but you can access the internal network, I'd guess you have some sort of routing problem.
My computer loves Microsoft ARGH!! HELP ME! team222badbrad Chit-Chat 12 29-01-2005 09:17
Number of Files on a computer Venkatesh Chit-Chat 14 22-12-2003 23:24
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
