Go to Post Don't start celebrating yet. I haven't a clue if we can get this working. - Kevin Watson [more]
Unread 29-01-2005, 13:18
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
CMU cam and Linux?
I'm trying to use the CMUcam frontend to test my team's CMU cam. The frontend starts up just fine but no matter what I do I cannot get a picture from the CMUcam. Has anyone gotten the CMUcam frontend to work on Linux? I am not allowed to install Java on my school's Window$ computers so I must get this to work on Linux.
By the way I'm running slackware 10.0 with Java 2 installed.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 29-01-2005, 18:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: CMU cam and Linux?
The GUI requires a Windows DLL (sserial.dll) in order to run. As for not being allowed to install Java, that's just ****.
However, as it has been said before, you could easily write your own (or, if you don't mind not seeing the image, just use a terminal app). If you need a base, the source came with the app.
Unread 30-01-2005, 23:02
AKA: Alan Meekins
A quick google search turned up a Java program written specificly for use on Linux with the CMUcam. It can be found here. I have not gotten a chance to test it out with the CMUcam yet but it was written by students at CMU so I'm sure it will work. But then again I love to re-invent the wheel so I'm thinking of making a custom app! I started reading through the code in SerialComm.java and found the following...
This file was a first attempt at making a cross platform
program.  This may seem strange, but this program switches
serial functions based on the OS.  Eventually I might get
around to using the java serial calls, but for now this
seems to work.
String tempOs = new String( System.getProperty("os.name"));
	if(tempOs.startsWith("Windows")) os=0;
	   else
	   os=1;
	if(os==0)
	    {//Windows
		System.out.println( "Windows Detected" );
		 int error;
        	error = serialPort.openSerial(new Integer(commPort).intValue(), 5);
        	if (error != 0) {
            	System.err.println("Error " + error + " during openSerial()");
		JOptionPane.showMessageDialog(null,"Can't open serial port!", "Port Error", JOptionPane.ERROR_MESSAGE );
		System.exit(0);
		serialPort.setReadTimeout(50); //Illah - make this much smaller?
        	System.out.println("serial port successfully opened!");
	else
	    { // Unix Serial Init
		System.out.println( "Unix Based System Detected" );
		try{
		    sPortIn = new FileInputStream( commPort );
		    sPortOut = new FileOutputStream( commPort );
		catch(Exception e){ System.out.println(e);}
This is supposed to switch serial functions when used on different OSes but it does not seem to work. The comment at the beginning of the file talks about a later version of this program using Java calls to communicate with the CMUcam. What are those calls and where can I find info on them?
