Go to Post No, no, no, it's a fire game. The pool is there in case of accidents. - artdutra04 [more]
Unread 28-01-2005, 21:37
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Question PWM connectors
Where are you buying the plastic 3 pin connectors for the PWM and input/output connections. I thought about sacrificing pmw cables but there must be a more cost effective way.
What is their technical name by the way. We call them "3 pin plastic connectors thingers" but that doesn't seem to yield to many results in digikey.com
Unread 28-01-2005, 21:53
jrmarenda jrmarenda is offline
AKA: Jason Marenda
FRC #1887 (Russet Robotix)
jrmarenda will become famous soon enough
Re: PMW connectors
Order them from Innovation First in the Accessories section.
Unread 28-01-2005, 21:56
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Re: PMW connectors
They're called PWM cables.
-Paul
Unread 28-01-2005, 23:23
dawonn's Avatar
AKA: Dereck
Re: PMW connectors
But I am not looking for the cables but rather the plastic connectors on the end of the wires for some custom circuts. I know I could sacrafice these cables just for the plastic ends but I feel the need to order a bunch of them and the corrasponding male connectors.
Seeing that I only need the plastic connectors, 60$ for seems a little wasteful.
Unread 28-01-2005, 23:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: PMW connectors
This may be a little cheaper http://robotcombat.com/marketplace_connectors.html (click on RC Cables and scroll down to the $2.99 one) but I know it isn't exactly what you are looking for. I don't remember the name of them off hand but I do know digikey sells them.
Unread 29-01-2005, 10:39
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: PMW connectors
Originally Posted by dawonn
Where are you buying the plastic 3 pin connectors for the PMW and input/output connections. I thought about sacrificing pmw cables but there must be a more cost effective way.
http://dkc3.digikey.com/PDF/T051/0098.pdf
Enjoy!
Housings - WM2801-ND
Female Pins - WM2510-ND
Male Pins - WM2517-ND
Crimper Tool - WM9999-ND
Note: the male tin pins I specified are quite a bit weaker than the PWM cables that are supplied in the kit, our team is using them this year with great success, but buyer beware. If you don't already have a crimper for these pins, I HIGHLY recommend buying the above crimper. We tried fabricating our own cables last year with ZERO success because of our poor homemade crimps. This year, we are having a MUCH easier time =).
Disclaimer: I typed those part numbers in haste and didn't verify them carefully. Please check your order carefully, and make sure they really are what you want.
-SlimBoJones...
Unread 29-01-2005, 10:54
Re: PMW connectors
My feeling has always been without the crimper, you will spend so much time fixing and making cables that you'd be better off spending $5 for premade cables. When you factor in the cost of just the connectors, pins, and wire, you are already in the several dollar range, so the savings isn't that much.
Unread 29-01-2005, 14:28
dawonn's Avatar
AKA: Dereck
Talking Re: PMW connectors
Thank you, I am going to place an order on these and try it out, With the crimper
I looked up buying all the cables we would need and then compared with making our own, we will save 24$. Hope this is for the best, We'll find out.
Unread 29-01-2005, 18:07
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: PMW connectors
Enjoy!
Looks almost identical to the once we used last year. Did you notice if they were lose or tight?? When we tried them they seemed very loose in the Victors?? Anyone try these specific onces and could verify this??
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Last edited by Gamer930 : 29-01-2005 at 18:10. Reason: Can't spell right the first time
Unread 29-01-2005, 21:24
Re: PWM connectors
Also, search eBay or www.towerhobbies.com for "servo wire" to get the three conductor "pwm style" cable.
Unread 30-01-2005, 23:29
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Re: PWM connectors
Cheapest I found anywhere on the web. Much cheaper than Digikey and Mouser:
http://stores.ebay.com/Hansen-Hobbie...QQsojsZ0QQtZkm
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 30-01-2005, 23:37
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: PWM connectors
Nice find. We've always used the molex part #'s above along with some 3 conductor 22 ga. wire, which is far cheaper than the servo wire. There is also an AMP equiv. with slightly better pins but the housings are wider which doenst allow multiple ones to be stacked next to each other.
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
