Go to Post Who wouldn't love to see a circular FRC field, on the backs of four elephants, all riding on a gigantic turtle? - Taylor [more]
Unread 28-01-2005, 17:45
stevex stevex is offline
AKA: Steve
#0219 (Team Impact)
Team Role: Electrical
stevex is an unknown quantity at this point
Send a message via AIM to stevex
Crimping/Soldering
This was talked about previously, but I wanted to add a little twist to it. What if (which I have done) crimped the wire already, would using solder be legal/make a better connection, OR would electrical tape over the crimp make a better connection?
Unread 28-01-2005, 17:59
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Crimping/Soldering
Soldering an already crimped wire isn't necessary, but it could add to the integrity of the connection. I do not know if it is legal or not. Electrical tape would not give you a better electrical connection, because it is not a conductor. Overall, the connection would be better being covered because it would have less of a chance of shorting out. Hopefully someone else can add to this to make it a more complete answer.
See you in DC!
Unread 28-01-2005, 18:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Any half decent inspector will make you tape exposed wire/connectors before they pass you.
Do yourself a favor and do it before the wire is on the robot where you can't reach it to tape it
2001-2004: Team 100
2006-Present: Team 254
Unread 28-01-2005, 19:05
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
The EE who works with my team always has us put a little solder on the tip of the wire sticking out of the top of the lug we crimped.
Unread 28-01-2005, 21:03
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Just a thought:
Electrical tape may be easier to handle and quicker to apply, but in the long run, I prefer heatshrink tubing - none of that sticky black residue or anything.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 28-01-2005, 21:15
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
This year, on our team we are making it mandatory that all wires be soldered to the terminals ( yes, ALL connectors) But since you cant get good access on the female spade terminals, we will use uninsulated ones and put heatshrink all the way down the connector.
For the past two years, we have had wiring trouble be it victors melting down, or battery terminals that weren't crimped, just taped ( yes just taped ) that will not happen this year.
We even purchased a 100/140 W soldering gun and a 40w soldering station, so no excuses for them this year. I might solder the battery lugs on with a propane torch myself though.
Unread 28-01-2005, 23:09
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
The best thing to do is crimp the terminals, fill them with a little solder, and heat shrink the wire. It looks really neat.
Team 302
Unread 28-01-2005, 23:31
Steve,
Soldering is legal. A correctly crimped connector when properly done makes an excellent connection, auto makers do it all the time. But when you are not sure of the crimp, soldering will give you extra confidance and slightly better resistance in the crimp area. Always follow up with a bare electrical connection with heatshrink or tape. If you need to open the connection then use tape. Tape over the crimp cannot provide enough extra pressure to tighten up the crimp so it does nothing but insulate the connection.
Unread 29-01-2005, 15:31
Haldir 122690's Avatar
Haldir 122690 Haldir 122690 is offline
Haldir 122690 is an unknown quantity at this point
a correctly crimped wire does not need to be soldered. in fact in military work soldering the connectors is prohibited.
Unread 01-02-2005, 08:25
AKA: Steve
#0219 (Team Impact)
Thanks Al and everyone for the advice, just wanted to check to see if the soldering was legal or not, after a crimp is already in place and got my answer so thank you!
Unread 01-02-2005, 08:32
Anytime!
