Go to Post Just like any good hardware or software product, "insert foot before putting mouth in gear"..... - dhitchco [more]
Unread 26-04-2002, 18:57
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
One way system
Hey,
I am using the compressor only to fill on air tank that i have. The tank is rated for 280psi, so i have the air gage inbetween the compressor and the tank. When the tank reaches 70psi, the compressor isnt putting anymore air into the system and starts making this whistling sound. I am running it off a 12V dc power supply, and i wanted to know if anyone knew why i cannot put in at least up to 120psi. Is it becuase the tanks that are handed out with this compressor are each only rated at 60psi, making a total of 120? Any help would be appreciated. Thanx
Unread 28-04-2002, 23:56
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
When you hear the whistling sound, put your hand by the overflow valve of the pump. If that is leaking air, then you've reached the max pressure that the pump will go. If it is less than 120 then something is wrong with the pump...try another one.
Unread 29-04-2002, 18:44
Andy A. Andy A. is offline
Getting old
FRC #0095
You almost certently have a leak.
Use some soapy water and dab a small bit (eye droppers work well) on each fitting, valve or anything of the sort. If you see lots of bubbles, you've found your leak.
Check that valve on the compresser first, it may be bad... We had problems with it starting to leak around 90 psi (we'd get up to 120 and then it would leak down).
-Andy A.
Unread 01-05-2002, 09:57
One of the many leaks we found in our system was the joint between the pump and the installed safety valve. Major Bubbles !!!! Once tightened, the pressure went up to about 120 psi.
Then there was the leaking ball valve (also from the kit) we used to exhaust the low pressure system ....
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
Pager system at Midwest Regional archiver 2000 2 24-06-2002 00:19
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
