Go to Post FIRST has taught me to mind my semicolons. - ComradeNikolai [more]
Unread 29-01-2005, 16:40
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
problem with void Process_Data_From_Local_IO
ok, this has been sort of annoying, mplab says that there is a syntax error in this line void Process_Data_From_Local_IO(void) this to me makes no sense whatsoever. also, it says that there is a syntax error on the last line of the program which is completly blank. here is the problem code
 * FUNCTION NAME: Process_Data_From_Local_IO
 * PURPOSE:	   Execute user's realtime code.
 * You should modify this routine by adding code which you wish to run fast.
 * It will be executed every program loop, and not wait for fresh data
 * from the Operator Interface.
 * CALLED FROM:   main.c
 * ARGUMENTS:	 none
 * RETURNS:	   void
 	  if (p3_sw_aux1 == 0 && p3_sw_top == 0 && p3_sw_trig == 0)
 		   auton_state = 1;
 	 else if (p3_sw_aux1 == 1 && p3_sw_top == 0 && p3_sw_trig == 0)
 		auton_state = 2;
 	else if (p3_sw_aux1 == 0 && p3_sw_top == 1 && p3_sw_trig == 0)
 		auton_state = 3;
 	  else if (p3_sw_aux1 == 0 && p3_sw_top == 0 && p3_sw_trig == 1)
 		auton_state = 4;
 	  else if (p3_sw_aux1 == 1 && p3_sw_top == 1 && p3_sw_trig == 0)
 		auton_state = 5;
 	else if (p3_sw_aux1 == 1 && p3_sw_top == 0 && p3_sw_trig == 1)
 		auton_state = 6;
 	 else if (p3_sw_aux1 == 0 && p3_sw_top == 1 && p3_sw_trig == 1)
 		auton_state = 7;
 	  else if (p3_sw_aux1 == 1 && p3_sw_top == 1 && p3_sw_trig == 1)
 		auton_state = 8;
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 29-01-2005, 16:51
Re: problem with void Process_Data_From_Local_IO
Originally Posted by CmptrGk
[/code]
The first error sounds like it really occurs earlier in user_routines_fast.c. Take a look at the line(s) before this routine and look for at least 2 open brackets that don't have matching close brackets.
You have one too many closing brackets "}" in this routine, but it doesn't complain, so I'd say you have too many open brackets "{" earlier in the file. That would explain why you get an error message about "void Process_Data..."
The error message on the last line usually means the compiler cannot resolve an earlier problem (such as too many open brackets).
Unread 29-01-2005, 17:14
CmptrGk's Avatar
Programming Mentor
AKA: Dillon
thanks, i belive it was caused by a missing bracket in case 4 in the autonomus section
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
