Go to Post Basically, just because you CAN do something doesn't mean you should and being savvy enough doesn't entitle you to being above the law. - Greg Needel [more]
Unread 20-01-2005, 22:08
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
2005 default code won't compile
I just tried compiling the 2005 default code v2.4 released on 1/12/05 and for some reason it refuses to compile. It says that it can't find the definition for function printf and stops the build. This is the code with absolutely no modifications. Just wondering if anybody has an idea what might be wrong.
Unread 20-01-2005, 22:53
Re: 2005 default code won't compile
Check the option settings of MPLAB.
Project -> Build Options... -> Project
"Include Path" should be C:\mcc18\h
"Library Path" should be C:\mcc18\lib
Unread 20-01-2005, 22:58
Robby's Avatar
AKA: Kevin Beranek
those are correct, it compiles code from last year and the 2005 code released on 1/7/05
Unread 20-01-2005, 23:50
The IFI site says that version 2.4 of the default code "works only with C18 Compiler (ver 2.4) from Microchip". Have you obtained and installed the new compiler?
Unread 21-01-2005, 11:26
Robby's Avatar
AKA: Kevin Beranek
i do have the new compiler
Unread 21-01-2005, 11:45
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Could you paste the exact error that the compiler is giving you? It would help us diagnose your problem.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 24-01-2005, 11:10
cibressus53's Avatar
cibressus53 cibressus53 is offline
cibressus53 is on a distinguished road
i'm experiencing the same problem, the exact error says
cannot find deffinition for function "printf" in (whatever file it's being called it)
it gives no compile error, just a build fail.
EMAIL: TERRYnospamP AHT MELDSTARspammenot DAWT COM
Unread 24-01-2005, 12:43
Do either of you still have the old compiler installed as well as the new compiler?
It seems like you are linking with an earlier version of the compiler standard library clib.lib.
That's where printf should now be coming from. Older compiler versions didn't have a printf in the library and teams used the IFI version in the project printf_lib as a substitute.
Unread 24-01-2005, 14:34
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Good call, Mark McLeod!.
I had issues initially, but based on past work experience, removed the old C ompiler and installed the new C compiler and errors went away. Some experienced computer users do this as a matter of SOP (standard operating procedure). Removing the old compiler program as completely as possible and installing the new MPLAB C-compiler may be your ticket to solving this kind of problem is good advice for high school students and for those of us who are a few year's removed from high school!
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 24-01-2005, 15:08
The readme file for the new compiler states that it can't be installed at the same time as the old compiler. They did make a change so that any newer compiler can be installed at the same time as 2.4, but it's not backwards compatible.
Unread 28-01-2005, 12:50
ElGeeko's Avatar
ElGeeko ElGeeko is offline
AKA: Kyle
#1375 (Megabites)
ElGeeko is an unknown quantity at this point
Send a message via AIM to ElGeeko Send a message via MSN to ElGeeko
I started off never having installed anything but MCC18 v2.4 on the team laptop (along with the GUI) and I still run into problems.
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "control.c" -fo="c:\code\code_v2.4\control.o" /i"C:\Dev-Cpp\include" /i" c:\code\code_v2.4" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
c:\code\code_v2.4\control.c:12: unable to locate 'ifi_aliases.h'
c:\code\code_v2.4\control.c:13: unable to locate 'ifi_default.h'
c:\code\code_v2.4\control.c:14: unable to locate 'ifi_utilities.h'
c:\code\code_v2.4\control.c:15: unable to locate 'user_routines.h'
c:\code\code_v2.4\control.c:16: unable to locate 'user_Serialdrv.h'
c:\code\code_v2.4\control.c:17: unable to locate 'user_routines.c'
error 1 spawning c:\mcc18\bin\cpp18
Halting build on first failure as requested.
BUILD FAILED: Fri Jan 28 00:07:44 2005
So, did I do something really stupid?
Unread 28-01-2005, 13:10
The space between the quote and drive /i" c:..." is "driving" it batty.
Typo's are so much fun
You also don't include mcc18/h, why is that?
Unread 28-01-2005, 15:45
ElGeeko's Avatar
AKA: Kyle
#1375 (Megabites)
I think I was trying to test out other include files but I originally did include mcc18/h and c:\mcc18\h as well as c:\code\code_v2.4. Of note also is that when I try and just compile the default code, every other source file has a similar error (the compile halts on first error after trying control.c).
Also, I was trying to do this in the gui, maybe I should do it right and go command line?
UPDATE:
Now the problem is that compiler cannot find stdio.h. What is stdio used for in this code (i.e. is it just used for printf and such)?
Unread 28-01-2005, 19:13
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Primarily printf(), but could be used for other things. Go to the project build settings amd set the directories to "suite defaults" (there's a button).
Unread 29-01-2005, 17:39
ElGeeko's Avatar
AKA: Kyle
#1375 (Megabites)
I had already tried that to no avail.
2005 default code kevin.fort Programming 33 20-01-2005 16:32
2005 RC Master Code or yaniv Programming 8 12-01-2005 12:05
2005 Manuals, FRC Default Code, Other resources Venkatesh General Forum 4 08-01-2005 14:06
Is default code already loaded? quickie25 Electrical 8 19-02-2004 22:51
