#31
Re: Controls and joysticks
For instance, I think that it would be OK to use a couple of IC's to hook up an XBox controller to the 15 pin serial (and I think you could too, use an IC to split the signal/ convert the packets into analog values), but attaching a pocket PC is definatly not cool.
(ok, so maybe it is cool, but only if it runs linux -- www.handhelds.org) |
#33
Playstation Controler
We are a rookie team so we're still learning about the game play and we are wondering if we are allowed to use a playstation controller instead of the joysticks provided.
Any help you can give would be appriciated Thank you for your time |
#34
Re: Playstation Controler
Well for one thing you would have to get a cord that transfer the joystick connector with the playstation controller and I am sure that there would be compatability issues. Now you could do this with a PC game controller but there would be trouble matching up the default code with this type of controller. In either case I do not think that the rules allow for that kind of thing.
#35
its allowed according to the rules (many teams have done it) it is just fairly difficult to accomplish. A playstation controller does not have a db15 end to it, so it couldn't be simply attached to the operator interface. pretty much the only way to do it would be to rewire the entire game pad.
#36
Chronic,
Check out this thread; it may be of some use to you: http://www.chiefdelphi.com/forums/sh...ad.php?t=28898 |
#37
I was looking at something like this as an option for our robot. There are a lot of controllers out there for the PC that are set up like a Playstation 2 controller. Like was mentioned before, the difficulty would be modifying the code to make it mesh with the controller.
#39
Cool! I never would have thought of that! Last year, we were going to try a controller that goes with videogames for the computer that deal with cars. That didn't work so well. As long as you have the time and your driver likes the idea, I would recomend it. Last year, my team decided that we would try to design our controll system on the preferences of our driver. We were a rookie team, so we didn't get that time.
#41
you cannot really use a ps controller, not because of the rules, but because of the way it is set up..
The controllers for FIRST are analog. PS controllers are digital.... it doesnt match, you will find some problems if you try it. |
#42
Hmm, Digital pots anyone?
If a microcontroller is allowed, you may be able to take whatever the controller of your choice and convert it to analog with a microcontroller, and output it to the OI with one of those. Of course that is one more thing to program, but if you can't get it done this year, why not in the off season? |
#43
I'm sure you can find a digital to analog converter online. Saying that something cannot be done, is always good inspiration for someone to find a way to do it. |
#44
#45
Question about controller/joystick method.
ok, I want to rig an Xbox controller as the main interface for our robot. I have converted them to USB before and have a USB driver and i was wondering if any of you had wiring diragrams of serial ports so i can figure out how to power it and where all the handshakes are. If so please let me know where i can find them. Thank you. Also is it legal to make an xbox controller the interface?
| Changing 1 joystick code to 2 (rookie team) | Brawler006 | Programming | 5 | 20-02-2004 17:00 |
| robot goes haywire with the one joystick default code | Miles | Programming | 7 | 24-01-2003 14:58 |
| Joystick controllers | archiver | 2001 | 6 | 24-06-2002 00:57 |
| joystick problem | archiver | 2000 | 12 | 23-06-2002 23:08 |
