Go to Post All this is sounding like gobbly-de-gook but it is important to understand this gobbly-de-gook. - ebarker [more]
Unread 29-01-2005, 19:16
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Controller disables itself after being reprogrammmed
For some reason our robot controller started automatically disabling itself every time it gets programmed, i.e. the rc mode light starts blinking red and the robot does not respond until it is reset using both the reset and programming buttons. I am running the new master code and the same thing happened with the previous master code version. It seems to have started doing this for no reason that I can determine. Has anyone had this problem and/or know how to fix it? I have searched the forums and I couldn't find what I was looking for, it doesn't seem that anyone has had this problem where it disables itself every time the rc gets reprogrammed.
Unread 30-01-2005, 08:57
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Controller disables itself after being reprogrammmed
Try downloading code with a different computer, it sounds as if either the cable or computer is corrupting the download.
Unread 30-01-2005, 10:13
Robby's Avatar
AKA: Kevin Beranek
I'll try, but does it make sense then that the code works exactly as it should after the controller is enabled?
Unread 31-01-2005, 13:07
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
No it doesn't make sense that the program is getting corrupted. It's possible, however, that some RS232 signal is not being propagated correctly.
Unread 31-01-2005, 18:11
Rookie Year: 1234
I'm guessing here after the program downloads, the IFI loader resets the robot controller. It could be that signal isn't reaching the robot, probably similar to having to hold PROG to download code. It's worth trying, and its pretty easy to do. (The other computer only needs IFI Loader and your hex file, nothing else)
Unread 31-01-2005, 22:00
Robby's Avatar
AKA: Kevin Beranek
I tried using both different cables and computers and neither made any difference. Any other ideas?
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
