Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 27-01-2005, 05:37
Phil Paspalas Phil Paspalas is offline
FRC #1676 (The Pascack Pioneers)
Phil Paspalas is an unknown quantity at this point
Re: camera power supply
BE CAREFUL! When we hooked up our camera yesterday, according to the instructions, we got the dreaded "puff of smoke" from the PC board. Any help? How much is a replacement? What did we do wrong?
Originally Posted by stephenthe1
where does the cmucam get its power from when hooked up to a serial port? I was thinking through the serial cable, but it doesn't show a positive terminal in the diagram on the serial cable. do you know where it gets power from when running the cam from the serial cable with an emulator (to install and test the firmware)? thanks for the help.
-Stephen
Unread 27-01-2005, 10:44
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Phil,
That puff was probably your 5v regulator. We had something similar happen, where it started pulling all the current we could give it. Luckily, we had it on a modular power supply, and could vary the current, so we never blew it out, but there was a definite short between +7.2 and GND. We did all sorts of testing, and in the end, something wierd happened and it started working perfectly again.
To test yours, hook 5v (a KNOWN 5V SUPPLY CAPABLE OF REGULATING CURRENT, NOT A BATTERY!) set the current regulator to about 200 milliamps, and hook the leads up to the GND and 5V pins on the regulator. If the camera still works in this setup, it's something to do with the regulator, or maybe something before that. If it doesn't, then a chip or something blew, and you're outta luck.
Good luck!
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 27-01-2005, 13:50
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
This is in response to a previous post about not needing to have the 12V battery connected in order to run the camera off of the pwm power. Well, yesterday our team just plugged the 7.2V battery in and not the 12V. What we measured was that there was no voltage across the pwm. So I guess you do need the 12V battery in addition to the 7.2V battery to power the camera.
Unread 27-01-2005, 14:04
Originally Posted by cabbagekid2
...So I guess you do need the 12V battery in addition to the 7.2V battery to power the camera.
What you need is for the RC to be running. When it shuts down, it removes power from all outputs, including the PWM power pins. The RC won't start up without a 12 volt supply, and with the 2005 firmware it won't run on backup power alone for more than a few seconds before it shuts down.
Unread 27-01-2005, 18:04
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
I found out the same thing.
Unread 29-01-2005, 15:32
why does First show the ttl adapter chip for the cmucam hooked up to the ttl serial port on the microcontroller when they are both male pins? so what's going on here? what should I hook up to what?
Unread 29-01-2005, 21:44
AnkurG's Avatar
AnkurG AnkurG is offline
Vice President
None #1072 (Harker Robotics)
AnkurG is an unknown quantity at this point
Send a message via AIM to AnkurG
Look closely on the TTL chip at hte IC where you plug in the PWM cable. On the sides of the IC there are small holes. You slip that part onto the RC. When I first looks at that my face was like this or this . So the way it works is that the PWM is connected to the TTL chip like regular, and then u place the chip on its side so it slips onto the TTL port all pretty-like. By the way, when the chip is on that port, it is extremely flimsy and can fall out pretty easily if a robot moves a lot and hits things in a competition. Will FIRST allow us to use electrical tape to tape it down since electrical tape is not allowed to be used as an adhesive?
Blood, Sweat, and WD40
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
need Computer power supply trick Tytus Gerrish Electrical 7 20-01-2005 11:25
12V Power Supply Feeds My Robot MikeDubreuil Electrical 17 31-03-2004 12:06
operator interface power supply hi_im_sean General Forum 1 05-02-2003 14:50
power supply of control system archiver 2000 5 24-06-2002 00:14
