Go to Post I'm going through waves of excitment and panic all at the same time. - je2164 [more]
Unread 30-01-2005, 00:01
sikon sikon is offline
#0122 (NASA Knights)
sikon is an unknown quantity at this point
Send a message via AIM to sikon
MPLAB on Linux
(Originally Posted in IT/Technical)
I seem to be having trouble running MPLAB on linux using the newest wine. I have seen it running on some laptops at competitions running linux, and am very curious. If anyone can help me please do so!
Unread 30-01-2005, 11:26
Re: MPLAB on Linux
It seems to be working fine with CrossOver office.
Unread 30-01-2005, 23:07
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: MPLAB on Linux
I was able to install the C18 compiler through Wine but the IDE complains because IE is not installed. I'll try installing IE. However, there may be a way to play with the registry and trick the MPLAB installer into thinking that IE is installed.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 30-01-2005, 23:37
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: MPLAB on Linux
I have it running well, but it's very hard to troubleshoot your problem if you don't tell us what it is. Error messages/symptoms/problems? I don't use the IDE, just wine for the compiler and a few makefiles (thanks jdong!)
Works great for me.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 31-01-2005, 16:42
Re: MPLAB on Linux
The newest CrossOver has IE 6 compatibility. If you install IE via CO you should be able to install at least MPLAB 6.00. Thats what I have discovered so far..
But if I try to execute it, the boot splash freezes. *shame*
Unread 02-02-2005, 08:19
nukem nukem is offline
nukem is on a distinguished road
Re: MPLAB on Linux
Well wince the compiler works fine under wine/cedega/crossover why not just use a native Linux IDE like kdevelop and point the C compiler to wine /path/to/mcc.exe? Personally I really dont like the MPLAB IDE.
Unread 04-02-2005, 06:58
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Re: MPLAB on Linux
Just use Makefiles & MCC through WINE. That way, you can program with your favorite Linux tool, whether it be KDevelop or vim.
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
MPLAB on Linux sikon IT / Communications 1 05-02-2005 15:06
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
