Go to Post Arguing about the rules doesn't change them. Fighting doesn't change them-and neither does feeling righteous. - David66 [more]
Unread 29-01-2005, 13:39
Srkasner Srkasner is offline
Srkasner is an unknown quantity at this point
Wheel Vendors?
Our team is going to use 6 inch diameter wheels in one of our prototypes. does anyone here know any good online vendors who would sell wheels with a 6 inch diameter and have 5/8 inch keyshafted center? Thanks
Steve
There are only 10 types of people in this world; Those who understand binary, and those who do not.
Unread 29-01-2005, 14:56
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Wheel Vendors?
www.skywaywheels.com
Ask them for the special FIRST order form in addition to what they have available for everyone to see. It has some other options.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-01-2005, 18:04
cnield's Avatar
cnield cnield is offline
#1318 (Issaquah Robotics Society)
cnield is an unknown quantity at this point
Re: Wheel Vendors?
http://www.ifirobotics.com/edu-motion.shtml
They sell foam wheels if you want those for some reason.
Never fight an inanimate object.
-P.J. O'Rourke
Unread 29-01-2005, 20:31
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: Wheel Vendors?
It may be tough to find wheels with the keyed hub that you are looking for. You may have to buy a wheel and design your own hub to press into it.
Some good places to look for wheels:
www.mcmaster.com
www.robotmarketplace.com
Team 121 is using 2" x 4" colson performa wheels (from robotmarketplace). They were around $7 each. We made our own keyed hubs out of aluminum and pressed them in.
Good luck in your search.
Rob
Unread 30-01-2005, 00:39
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Re: Wheel Vendors?
We just got our AndyMark 6" Trick Wheels in the mail and they are all I hoped they would be. AndyMark also sells hubs with a 1/2" keyed hole.
http://www.andymark.biz/products.htm
Thanks Andy (and Mark)!
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 30-01-2005, 00:40
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Wheel Vendors?
Generally you can search on industrial suppliers like mcmaster and wheels. Usually the sizes appropriate for robots are under the caster wheel category, but you can just page through their catalog. You can also do a Google search for caster wheels. Skyway and robot marketplace though are the two best places to look for wheels that are easy to mount to robots though. So I'd look their first and see if you can find what you need.
Team Website
Unread 30-01-2005, 00:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Wheel Vendors?
There's always the option of making your own wheels . Also, www.northerntool.com sells wheels under the "low speed wheels and tires" category but I think all their products are on robot marketplace too. Also, you might find some here http://www.npcrobotics.com/products/index.asp
Unread 30-01-2005, 16:19
IndianChieftain's Avatar
IndianChieftain IndianChieftain is offline
FRC #1241 (Theory 6)
IndianChieftain is on a distinguished road
Re: Wheel Vendors?
The simplest thing to do is probably make them. 1241 started on the project and are still working to get it done. the weight is not really a problem assuming, you would use aluminum for the wheel and put treads on the wheels. you can keep them down to about 1 1/2 to 2 lbs max.
04-05-Regional Champions - Waterloo (Thanx 1305 and 68)
04-05-Team Spirit Award - Waterloo
04-05-Entreprenuership Award - Waterloo
03-04-Rookie All-Star award - Great Lakes Regional
03-04-Rookie Highest Seed - Greater Toronto Regional
03-04-Rookie All-Star award - Greater Toronto Regional
03-04-Damier Chrysler Team Spirit award - Greater Toronto Regional
03-04-Damier Chrysler Team Spirit award - National Championships
Four wheel drive question haverfordfords General Forum 25 25-01-2005 23:24
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
