Go to Post FIRST doesn't graduate you from HS ... your performance in class (your grades) do. - Franchesca [more]
Unread 30-01-2005, 02:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Kitbot transmission plate
Originally Posted by Stonefan5271138
Actually...why would you 'have' to cool the motors? They're good motors and they havn't burned out. We actually raised our robot and had it go full speed foward and had the wheels run for lik, 20 minutes or so and the motor didn't even get warm.
That's exactly what I'd expect to happen, given you're running them under no load.
Run them near stall and they'll get hot a lot faster.
But like has been said many times before, by the time the surface of the motor gets hot, you've damaged the internals of the motor irreparably.
2001-2004: Team 100
2006-Present: Team 254
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
Gearbox Lord Nerdlinger Motors 20 15-07-2003 00:38
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
