Go to Post I love the dedication of Robotics kids. :) - Danielle H [more]
Unread 29-01-2005, 19:19
rcubes85 rcubes85 is offline
no team (TBD)
rcubes85 is on a distinguished road
Send a message via AIM to rcubes85
How are the Goals held down
I heard that the goals are held down by Velcro. Didnt anyone that went to the kickoff notice this, or it is held down tight enough such that when these 120 pound robot hit it, it wont be dislogged from the field
you can run from the past
you can change the present
but you can't outrun the future
becuase what you do in the presents depicts your future
Unread 29-01-2005, 19:24
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: How are the Goals held down
They can be moved with a bit of force -- if you do you get a penalty.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 29-01-2005, 19:26
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Yes, The goals are held down by industrial Velcro to the carpet. I personally do not expect the goals to budge much during the competitions. When we went to pack the field up after kickoff in Manchester, it took a couple guys to lift each goal and get the Velcro undone.
-Michael Dessingue
cnield's Avatar
cnield cnield is offline
#1318 (Issaquah Robotics Society)
cnield is an unknown quantity at this point
You would need a lot of force to move the goals. They are held down by Velcro on all surfaces touching the ground.
I believe that this was covered in update 2 of the rules on FIRST's site.
Never fight an inanimate object.
-P.J. O'Rourke
Unread 29-01-2005, 20:26
Billfred's Avatar
Billfred Billfred is offline
I think I managed to yank a few off their base solo.
Still, I highly doubt that you'll be able to knock over a goal unless you're really trying to knock over a goal.
(Alright, maybe the center goal will be a bit easier to do, as it's not all one piece. Time will tell.)
Unread 29-01-2005, 23:36
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
I beileve that the Stairs and platforms were held in place last year with The same Velcro and i know there were a few instances where they were moved, so i predict that yes it will happen but i think its somthing that teams are gonna have to compensate for, believe it or not, but Strategy is a rather important part of these games
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 30-01-2005, 03:31
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
I don't think they will penalize you if it is an accident if you move the goal. I thought they would have bolted them down somehow, but i do see that it would be easier to fix if all it was held down on was Velcro. Also, how much does a goal weigh? Shouldn't that weight with a couple of tetras on top hold it down?
Elknise
Issaquah Robotics
Unread 31-01-2005, 17:03
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
As you've all stated, the "fixed" field elements (the nine goals) are all affixed to the field with Velcro.
Now, do the math. If a tetra weighs approx. 8.5 pounds, then the eight goals weigh about 20 lbs. each (not including the center goal).
With a 100 lb robot coming at you at over XXX feet per second, don't you think that the Velcro will get "accidentally" budged?
But, do the math again. If all bottom surfaces of the goal (about 18 linear feet) are covered with "industrial-strength" Velcro, then the sideways "shear" strength will take a LOT to really move it. Lifting vertically or prying-it up may be possible, but I doubt that a sideways hit will dislodge a goal.
HOWEVER....If you get "under" a field goal or "disrupt" it per rule <G20>, you will get ONE WARNING. If your action changed the outcome of the match, your robot will be DISABLED. If your robot TIPS-OVER a goal, that goal automatically "belongs" to the other alliance.
So.....Sure, the goals will get "nudged". The should stay in place and will likely be checked and reset as needed between matches. But you can't intentionally RAM a goal......I guess that's why the call it "gracious professionalism"
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 31-01-2005, 17:23
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
I don't think too many goals will be moving around on the feild. Velcro can get pretty strong. Plus, most of the time, you dont ram goals, it doesn't profit you a whole lot...
Unread 31-01-2005, 18:45
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
The platforms didn't move much, though. I predict the same with the tetras. When they move, it won't be very far at all. I think it'll take a concerted effort to move them far enough to be DQed.
Jeff Waegelin
Are the goals bolted to the floor? Leav Rules/Strategy 1 11-01-2005 03:31
Mobile Goals Joshua May General Forum 12 16-03-2004 10:45
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
WOW ! Mike Schroeder General Forum 12 12-03-2002 21:32
