Go to Post Are quadcopter rotors considered a pneumatic device? - bobbysq [more]
Unread 30-01-2005, 08:14
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Old Joysticks - Where to buy?
Originally Posted by Xufer
ch prodcts made a newer version of the joystick that is still ported to a game port heres a link : http://www.chproducts.com/retail/j_fighter_pc.html
Just a warning - even though a joystick may physically have a 15-pin D-Sub Gameport connector, you shouldn't assume it's compatible with the Operator Interface. Some 15-pin joysticks, including the updated CH stick listed above, have numerous hat switches and pushbuttons and internal electronics that permit programmability of all the joystick features. The circuit board requires external power to operate, and since no such power is available or legal during a FIRST event, chances are, this kind of stick will not work with the OI without some internal rewiring to bypass the electronics. Unless I am mistaken, there is nothing in the Robot Rules, rule <R55> specifically, that forbids internal rewiring of game controllers this year, so you could try to bypass the circuit board completely and wire the joystick's throttle, x and y axes, and digital switches directly to the 15-pin connector to make the stick fully compatible with the OI.
Your best bet for a replacement joystick that "works" out of the box - if the joystick in question has a 15-pin connector and at most four pushbuttons (a trigger, a top button, and up to two other buttons), with an analog throttle wheel and possibly an analog hat switch (like the Kit joystick has), you should be good to go. Remember, the OI supports a max of 4 analog inputs and 4 digital inputs on each port.
Unread 02-02-2005, 21:51
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
With everyone looking for old controllers I am assuming that the old black controllers are still legal right?
our web site
Unread 02-02-2005, 22:43
Right. They are still legal.
number of joysticks Waste General Forum 21 27-01-2005 15:04
Sophisticated Joysticks WebWader125 Control System 3 03-12-2004 15:33
need joysticks! Tom Bottiglieri General Forum 14 24-02-2004 09:36
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
FIRST FYI: Best Buy Children's Foundation Grants Rich Wong FIRST E-Mail Blast Archive 16 01-12-2003 20:57
