Go to Post Lawrence North has air conditioning. If it didn't, more than just balls would be sticky. - Andy Baker [more]
Unread 30-01-2005, 11:54
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Red face Re: Kitbot transmission plate
I don't know if our CIMs will heat under a load yet. I am anticipating that they might.
What I am hearing from replys to this and another post is that adding a cooling fan outside the case of a motor is of no consequence. Cooling by an external fan does nothing to prevent damage inside.
http://www.chiefdelphi.com/forums/sh...ad.php?t=33313
I can't say if we have our transmission geared correctly in the power curve but am trusting the FIRST volunteers who designed the kit transmission. We are using the unmodified stock kit componants with the 8" x 1" wheelchair casters in a four wheel drive configuration.
I still consider it prudent to add some air movement to aid in the radiant cooling of the motor cases. I will not consider it a top priority in the design and just find a location to intall a fan to get some air moving in the vicinity of the motors.
Thanks,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
Gearbox Lord Nerdlinger Motors 20 15-07-2003 00:38
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
