Go to Post I don't remember who said it or what the words are exactly...(I think it was Hopalong Cassidy) Don't say goodbye, just say see you later. - Al Skierkiewicz [more]
Unread 29-01-2005, 05:46
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
printf problem
I'm working with floats for calculations. I'm trying to use a printf statement to display the value of various floats, but I keep having problems. When I use %d, I get a wacky number over 37,000 which makes no sense. When I use %f, I get no output of the number at all. Could somebody tell me what I'm doing wrong. Here's an example of the format of how I'm doing my printf.
printf ("Value: %f /n", (float)value_name);
I've tried it with %f and %d... as well as trying to use my variables as "double" as well. Same problems though. Any help would be very much appreciated. Thanks!
Unread 29-01-2005, 08:38
logicalhippo logicalhippo is offline
AKA: Russell McClellan
#0213 (Dirty Birds)
logicalhippo is an unknown quantity at this point
Send a message via AIM to logicalhippo
Re: printf problem
printf does not support printing of floating points :'(. sorry, it just doesn't work. (see the comment in printf_lib.c)
What SHOULD work is using %d and then explicitly casting the float to an int.
IE: printf("%d\n", (int)fFloat);
Unfortunately, for me, this ALWAYS prints 0, no matter how large fFloat is.
I'm still having trouble with how to convert floats to ints. I wrote a quick function in c that I'm going to test today, and I found assembly routines from 1997 (see product note AN575 on microchip's page) that I will try.
Around here the consensus seems to be that floating points are more trouble than they are worth on this processor. In most cases where you would use floating point on the robot it's possible to do the math in the integer domain by multiplying first then dividing down.
Unread 29-01-2005, 16:54
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: printf problem
If you're using the new compiler, I believe the printf() included in that works with floats (check the documentation in .\mcc18\doc).
Unread 29-01-2005, 19:06
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: printf problem
Ok so I am having the SAME problem. I can't see if my float calculations are working or not. Did you see the README in the IFI released camera code:
www.InnovationFirst.com
1/8/2004
-   Removed printf_lib.c and printf_lib.h - now using <stdio.h>, compiler needs -nw=2066 to suppress warnings
-   Added user_camera.c and user_camera.h - to remove code from build -> remove the _USE_CMU_CAMERA macro
-   Replaced file named PicSerialDrv with user_serialdrv
-   Note:  when using a 'printf' use a '\r' rather than a '\n' with the new compiler (v2.4)
So I am not using print_f.lib. I am using stdio.h. I am doing the same thing as
miketwalker but I don't get anything to the screen while trying to use floats.
Has anyone else got any input? I am using MPLAB, not CBOT, and the new 2.4 version complier....
I spent all day wondering if our float calculations are actually working.
Is float supported in this PIC?
Can I even do a calculation like this?
If WHEELBASE = 485.35 mm?
pos_mm_theta = (pos_mm_Left_Encoder_Count - pos_mm_Right_Encoder_Count)/WHEELBASE;
posx_mm = pos_mm_distance * sin(pos_mm_theta);
posy_mm = pos_mm_distance * cos(pos_mm_theta);
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 29-01-2005, 19:58
AKA: Jamie Bliss
Re: printf problem
No.
Yes.
The PIC18 does not contain a floating point unit or floating point instructions. All floating point math is handled in software and handled inline by the compiler. This is why all floating point math takes a long time, and is highly discouraged.
However, from looking at the documentation, it appears that floats are not supported by printf() and related functions. See section 4.7 in .\mcc18\doc\MPLAB-C18-Libraries.pdf for the formats supported.
Unread 30-01-2005, 12:01
Re: printf problem
To print floats you can always use a little manipulation like:
#define ACCURACY 1000	//How many decimal places are important to you
float f;
int i, i2;   // Might need to be longs if you have a lot of significant digits
f = 245.56;
/* Print float value */
i = (int) f;
i2 = (int) ((f-i)*ACCURACY);
printf("f = %d.%d \r", i, i2); //e.g., f = 245.559
Unread 31-01-2005, 13:11
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: printf problem
float f;
f = 245.56;
i = (int) f;
printf("f = %d.%d r", i, i2); //e.g., f = 245.559
You're going to want to be sure leading zeroes are printed for the fractional part. Does this printf implementation support "%03d"?
Unread 31-01-2005, 13:19
Re: printf problem
That's very true. I neglected that.
We should verify that the leading zeros can be forced. I'll call one of my kids later to test it on the controller at school to be sure.
[edit] That is supported (and has been tested), so the corrected printf would read:
printf("f = %d.%03d \r", i, i2);
Thanks Greg.
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
printf problem cbolin Programming 4 09-11-2004 02:44
Anyone with a replacement Printf? Larry Barello Programming 5 19-03-2004 02:20
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
