Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 29-01-2005, 12:26
wmurphy wmurphy is offline
#1529 (Cyber Cardinals)
wmurphy is an unknown quantity at this point
Blown Victors - WHY?
We built a prototype robot that worked fine using a base plate of press board to mount the electronics; however, when we changed the press board to a metal plate - TWO VICTORS BLEW! What is the problem? Continuity tests check out O.K. Victors did not blow until joysticks were moved.
"MURF"
Unread 29-01-2005, 12:32
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Blown Victors - WHY?
Were you cutting metal around them? If you happen to get metal shavings inside, they will burn out very easily. This is apparently a fairly common problem, though I can't imagine why people actually do this.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Did you drill holes in the metal plate near the electronics? If so you may have gotten scraps of metal into the Speed Controllers causing them to short. We had that problem last year.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 29-01-2005, 12:38
We were fairly conscientious about making certain that at least the second victor was "metal scrap" free. At this point, I'm kinda "gun shy" about moving back to the press board even ...
"MURF"
Unread 29-01-2005, 12:40
Running Riot
AKA: Patrick Cloke
You could take the screws off (and void the warranty) to see if there are metal scraps in it. Its much easier than it seems to get metal in them. Ideally you want to take the electronics off when doing things like that.
FIRSTsearch
Der Sichelmann's Avatar
Der Sichelmann Der Sichelmann is offline
Professional Team Member
#0358 (Eagles)
Team Role: Student
Der Sichelmann is an unknown quantity at this point
After our experience, we are extra careful Our engineers built a tester to find bad controllers and we ordered the parts to fix them.
Unread 29-01-2005, 22:57
Andy A. Andy A. is offline
Getting old
FRC #0095
Top four reasons why Victors 'blow'.
1. Metal shavings shorting out the power FET's
2. Reverse polarity. The new housings this year don't mark which terminal is which, so this could happen easily enough. I believe that
3. Being dropped.
4. Angering the electronics god.
Not much you can do about any of those, except #4. If thats the case, sacrifice 12 Dews upon an alter of Bridgeport consecrated by WD40 on the eve of ship date.
-Andy A.
Unread 30-01-2005, 01:00
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
It was probably just as other people said, some metal shavings that brought out the magic smoke.
Unread 30-01-2005, 11:45
occra 23.
AKA: ryo
None #1481
shorting. metal. reverse ploarity. or overload (which i guess will fall into shorts). or moisture inside.
Unread 30-01-2005, 15:18
In addition to the above suggestions, might I add the following...
Remove the output wiring from the controller and check the Resistance of the wiring with a good VOM. It should be low but not zero. If it is zero than disconnect one of the motor leads and try again. If it is still zero, check for continuity from each of the output wires to robot frame. It is possible that when moving to the metal frame some wires were damaged or crimped under the mounting hardware. If you ran wiring through a metal channel on the metal base, someone may have drilled through the channel and into some wiring shorting the wires. My bet is shorted wiring or reverse wiring on the controllers. I would mark each controller for input voltage and motor output so there will not be confusion when mounting or wiring the controllers.
Unread 30-01-2005, 15:24
Umm Errr...
Are you sure the victors are really bad? in my experience about 85% of speed controller issues are really PWM cable issues. What are the symptoms of blown-ness?
After that i would check for metal shavings in the fins of the FETS. At different times some are HOT and others a Ground..... metal shavings from hot to ground = bad!!
This may sound stupid bit is worth mentioning. Don't blow compressed air into the victor fans.. It makes them go VERY fast and produce a voltage the the victors are not designed to withstand.
Fun little experiment:
Take one of those useless little muffin fans included in the kit and blow conpressed air through the blades. If you get the angle right, it will spin unbleievably fast and make an earsplitting noise. Don't do this to a fan you are using.
1139 Alumni
Unread 02-02-2005, 22:45
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
If its the aesthetics you are woried about, then why dont you mount the electronics on Plexiglass or Lexan?
Unread 03-02-2005, 08:30
Running Riot
AKA: Patrick Cloke
If you do find out it is the Fets that are causing the problems, you can replace them much cheaper than replacing the entire speed controller. I believe it voids your warranty but Fets are quite cheap - maybe $.75 or so each.
We also developed a tester for speed controllers to see if they're working or not, I don't know the specifics on that however. I'll find out later and post more.
FIRSTsearch
Unread 03-02-2005, 18:22
roboticsjenkins's Avatar
roboticsjenkins roboticsjenkins is offline
robotics_jenkins
AKA: Andrew
#0616 (Southampton Indian Robotics)
Team Role: Electrical
roboticsjenkins can only hope to improve
Send a message via AIM to roboticsjenkins Send a message via Yahoo to roboticsjenkins
They blew because you probably grounded the Victors out because I had that problem last year. It's better to mount them on a piece of material that is not a conductor of electricity......Thats my guess
Unread 03-02-2005, 21:50
Just curious - do you know the FET part #s and a good source for them? Thanks!
"MURF"
24Vs and victors greencactus3 Control System 13 05-02-2005 14:22
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
Flakey Victors archiver 1999 4 23-06-2002 21:58
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
