Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Unread 29-01-2005, 04:10
karch karch is offline
In Zip Tie Heaven
AKA: Brian Liu
FRC #1510 (Westview Robotics)
karch is on a distinguished road
Send a message via AIM to karch
Unhappy Confused about Interrupts
why is it that in setting up priority levels for interrupts, the parent intcon number changes:
INTCON3bits.INT2IP = 0; // Pin 1
INTCON2bits.INT3IP = 0; // Pin 2
INTCON2bits.RBIP = 0; // Pins 3, 4, 5, 6
but in setting up edge select, pin 1 and pin 2 are both intcon2bits:
INTCON2bits.INTEDG2 = 1; // Pin 1
INTCON2bits.INTEDG3 = 1; // Pin 2
and then when setting interrupt flags, they both turn into 3s?
INTCON3bits.INT2IF = 0; // Pin 1
INTCON3bits.INT3IF = 0; // Pin 2
INTCONbits.RBIF = 0; // Pins 3, 4, 5, 6
(not to mention pins 3,4,5,6 going from 2 to no number)
i got this code from the interrupts_for_dummies pdf in the white pages, so i'm assuming that this is correct code.
is it all just arbitrary, or what? what am i missing here?
Unread 29-01-2005, 05:28
Electrical Engineer
Rookie Year: 1995
Re: Confused about Interrupts
Hardly arbitrary. Read chapter 10 of PICmicro® 18C MCU Family Reference Manual
Mike Betts
As easy as 355/113...
Unread 29-01-2005, 08:44
logicalhippo logicalhippo is offline
AKA: Russell McClellan
#0213 (Dirty Birds)
logicalhippo is an unknown quantity at this point
Send a message via AIM to logicalhippo
indeed. The documentation usually helps :-P.
INTCON3 is an 8-bit register in the microcontroller. Since there are 8 bits, it can hold 8 binary values. The reason there are multiple INTCON (interrupt control) registers is that there are more than 8 binary values needed to control interrupts.
Seriously, if you're doing something as low level as interupts, scan the datasheet and get familiar with the processor. It'll do you good in the end.
Unread 30-01-2005, 12:42
In Zip Tie Heaven
AKA: Brian Liu
alright, understood.
but it'd still be nice if they at least tried to be a little consistent...
Unread 30-01-2005, 14:03
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
To the interrupt-capable amongst us, an additional conundrum. From reading Interrupts for Dummies, it appears that Dig IO pins 1-6 can be used for interrupts.
Why then, does Kevin's encoder routine use pins 1 and 6 for one side and 2 and 8 for the other?
If you want to use other Hall encoders, how many can you use? is 6 the magic number, or is only 2? (pins 1 and 2)
Jon from Team 236
Unread 30-01-2005, 14:09
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
It doesn't. It uses 1 and 7 for one, and 2 and 8 for the other. 1-6 can be hardware interrupts, and 7-16 cannot. This means that you're pretty much limited to six digital encoders.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 30-01-2005, 14:30
Jon236's Avatar
AKA: Jon Mittelman
This is in the encoder.c file:
Five things must be done before this software will work
* correctly on the FRC-RC:
* 1) The left encoder's phase-A output is wired to digital input
* one and the phase-B output is wired to digital I/O six.
* 2) The right encoder's phase-A output is wired to digital input
* two and the phase-B output is wired to digital I/O 8.
* 3) Digital I/O pins one, two, six and eight are configured as
* inputs in user_routines.c/User_Initialization(). If you notice
* that the encoder only counts in one direction, you forgot to
* do this step.
* 4) A #include statement for the encoder.h header file must be
* included at the beginning of each source file that calls the
* functions in this source file. The statement should look like
* this: #include "encoder.h".
* 5) Initialize_Encoders() must be called from user_routines.c/
* User_Initialization().
has it been changed?
Jon
Unread 30-01-2005, 14:51
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
* do this step.
Jon
Whoa, that's weird. I apparently have an older version; my encoder.c looks completely different from what I just downloaded from kevin.org. Yeah, that doesn't make any sense to me... it should be on 7, not 6.
_
Unread 30-01-2005, 16:23
Kevin Watson's Avatar
La Cañada High School
FRC #2429
No, 6 & 8 is correct. I changed it because I got a nasty gram from someone who hadn't made I/O 7 an input, which caused the encoder to count in one direction only. 6 & 8 are inputs by default. This text was added to the readme.txt file for this very reason:
do this step.
-Kevin
Kevin Watson
http://kevin.org
Unread 30-01-2005, 19:23
Jon236's Avatar
AKA: Jon Mittelman
Kevin,
So for quadrature sensors, how many can we use? I would like to use 2 others, for a total of 4 (including the L & R wheel ones). Is that possible? Which pins should I use?
Jon
do this step.
-Kevin
Unread 31-01-2005, 07:15
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
yes, but I think he wants help setting up the interrupt code to support 4 interrupts, versus the two it already has. I have the same problem. I'm gonna try to add to Mr. Watson's template to handle 2 more quadrature encoders (phase a and b encoders), and I'll test it on last year's bot. I may, however, need a little help on referencing digitals 3-6 as interrupts, since they are banded together.
Unread 31-01-2005, 09:51
Electrical Engineer
Rookie Year: 1995
When you read port B, the bits will tell you which interrupt was "tripped".
Mike Betts
White Paper Discuss: Interrupts for Dummies CD47-Bot Extra Discussion 5 29-01-2005 03:24
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
INT2 and INT3 interrupts not working Mercutio Programming 4 01-02-2004 13:27
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
Finding myself quite confused... Alphawolf829 Robotics Education and Curriculum 8 16-12-2002 20:19
