Go to Post A few years of stress is worth a lifetime of opportunity. - omegasis25 [more]
Unread 29-01-2005, 11:30
Obi's Avatar
Obi Obi is offline
Obi is an unknown quantity at this point
Camera Servo
In my custom code, I have three positions I set the pan and tilts to. None of them are the 127,127 position, but wheneverI change them, they immediately move back to 127,127. Is there code in other parts that set the servos to 127,127 after initializing or anything? Thanks.
Edit:
Also, is there a way to use the camera_set_servo command and not have to do camera_init again? Everytime, after I initialize the camera and tell it to go to a specific servo position, I don't get any camera feedback. And if I try to initialize again, it goes back to 127,127. Thanks.
[hr]
Southold Robotics Team #870 (RICE)
Unread 29-01-2005, 15:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Camera Servo
From my experience with calibrating the cam, it always rotates back to home after its done. Not sure how to change that though =/
http://www.mikesorrenti.com/
Unread 30-01-2005, 17:09
kutty18 kutty18 is offline
#0234 (Cyberblue)
kutty18 is on a distinguished road
Send a message via AIM to kutty18 Send a message via Yahoo to kutty18
Re: Camera Servo
If you enable autoServo() & call findColor(), will the camera automatically start searching (I mean, panning horizontally & tilting vertically) the field? If so, can you restrict the amount (46-210) of panning and tiliting so that we can save time by searching only "useful" places? If not, how do you move servo horizontally and vertically to search the field? We tried to manually set servos, but it seemed to be really slow...Thanks.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Have you gotten your robot to go towards the vision tetra? Bharat Nain Programming 20 25-02-2005 20:18
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
Camera Range Finding russell Programming 9 31-01-2005 19:54
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
