Go to Post No such thing as asking too much. There is such a thing as asking too fast, but not too much. - EricH [more]
Unread 30-01-2005, 19:36
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
Radio Reception?
Has anyone had any problems with radio reception? Any tips for mounting it? How much would sheet metal (various thicknesses) block it out?
I've done some searches and theyall came up dry.
Unread 30-01-2005, 19:45
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Radio Reception?
Make sure that the antennae are in view of each other...
I do not see why you would have the radios being split between two sides of sheet metal... how would you be able to see the robot when your trying to control it, the CMUcam, would that be good enough?
- from B B frank
Unread 30-01-2005, 19:49
KVermilion's Avatar
... clearly ...
#0649
That's going to be really hard.
Unread 30-01-2005, 19:51
AIBob's Avatar
AI Programmer
which part of what I said would be hard?
- from B B frank
Unread 30-01-2005, 20:10
KVermilion's Avatar
... clearly ...
#0649
The part with no metal in the line of sight.
Unread 30-01-2005, 20:47
Umm Errr...
Unless you build something like a cylinder or whatnot around your modem, i wouldn't worry about placement too terribly much.
Some general advice:
*Polarize both antenae the same: IE if the modem attached to the OI is mounted horizontally, mount the one on the robot horizontally. Or mount them both vertically.
*if possible mount the modem in an area without too much metal.
*generally the higher the better, but make sure its not going to get hurt
*DO NOT mount the the modem so that the antenna is surrounded by sheet metal. You don't want to make a faraday cage.
1139 Alumni
Unread 31-01-2005, 07:45
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
I would not worry about it too much as our team seems to always have lots of metal around the radio.
our web site
Internet Radio Stations cibressus53 Chit-Chat 2 26-10-2004 00:28
Radio Problems KWalsh Programming 3 24-02-2004 17:25
Radio Cable Burning!!! Cadetdan Electrical 10 15-02-2004 09:46
radio transmitters Arin Technical Discussion 2 18-12-2002 01:59
