Go to Post where theres building to do, i'll be there. - Conor Ryan [more]
Unread 30-01-2005, 21:56
ginger ginger is offline
ginger is an unknown quantity at this point
Re: Keeping the Chuck on the mill
Are you using a drill chuck to hold an end mill?
Please don t do that- drill chucks are made to hold drills, and to drill holes. End mill holders or colletts are made to hold end mills. There is nothing you can do to a drill chuck and its morse taper socket to make it hold well enough to use for milling.
In addition, drill chucks never run dead true, so holding an end mill in one causes it to become a one tooth cutter.
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Mill Suggestions? phrontist General Forum 29 27-02-2005 14:00
CNC Mill Help Rickertsen2 Technical Discussion 8 25-08-2004 00:59
Haas CNC Mill Graph Function P-Dog Technical Discussion 9 13-03-2004 23:45
1/2" #20 threads keyless chuck needed Jeff Frangenber Motors 3 13-02-2004 07:54
