Re: pic: Team 45 teaser
We have three of them mounted on the robot, all in a straight line (figure how that works if you can). Slip in any direction is expected and accommodated. The software to deal with them is surprisingly simple (except for the extra hoops it takes to use the third hardware interrupt). |
If they are in a line but not oriented the same way, then I know how you are doing it. I realized that would be a better after that rendering was made months ago.
I assume there is going to be a torsion spring at the shaft (or a compression spring on the arm itself), or are you having gravity do the trick? Last edited by Max Lobovsky : 31-01-2005 at 12:37. |
Gravity will probably be sufficient, but there's a small torsion spring just in case.
| pic: Team #1382 Teaser - Gear Box | tribotec_ca88 | Extra Discussion | 6 | 22-01-2005 20:02 |
| pic: Team 48 Teaser (?) - xtremachen 7.314159 | Travis Hoffman | Extra Discussion | 8 | 22-01-2005 11:37 |
| Real names, please | Andy Baker | General Forum | 131 | 21-07-2004 22:07 |
| pic: Team #93's robot "Tobor 7" Teaser | CD47-Bot | Robot Showcase | 45 | 23-02-2004 16:03 |
| pic: Team 772 Teaser | CD47-Bot | Robot Showcase | 11 | 21-02-2004 21:18 |
