Re: Operator Interface Control Panel
We used some 1x4" wood, with a groove ripped down the bottom to allow a piece of 1/8" lexan in to hold the OI. There was some more 1/8" lexan attached to the top with some small hinges and secured with velcro. The joysticks (3) were attached to the lexan using velcro as well. The box was also designed to split apart to give the drivers some room to breathe.
I wouldnt worry about the control panel until the robot is done and your drivers are selected. Talk to them about how they want the panel layed out, and go from there. Lexan and wood work great, but I have seen some controllers made from aluminum and diamond plate. Keep in mind you might have to lug the controller around (by hand) through the queue at the competition(s), so try to keep it light. Also, try to keep your OI visible, and make sure you keep the competition port OPEN. You need to be able to plug the cable DIRECTLY into the competition port at the driver station. |
Another good material to use is Metal (Diamond Plate) - although it has weight diamond plate looks good up against anything.
You want the Control Deck as I call it user friendly and easily maintainable as well as user accessible. Attach what you need (joysticks etc) to on any surface material make sure you leave enough slack in the wiring, the radio modem must be free at all times (can't be tied down but velcroed to an area is ok) and it must be made rugged, Ups and Downs. Lexan - I don't happen to like Lexan only b/c it can get scratched and or cracked depending on its thickness. But hey where just building something to hold joysticks and wire right. I belive its lighter then wood. Wood - Its Simple you just drill holes in a piece of plywood and use zip ties to tied down everything =) since velcro don't particulary stick to wood that well, or you can use duck tape. =p Metal - A thin sheet of metal ( as said b4 diamond plate) is good, you don't have to worry about the surface scratching as much ( just a thought) and it can't break. just about anything can be applied to metal surfaces ( tape , velcro) An old school I worked with had 2 different types of control decks - 1) Plywood, Mahagne - >>> spelling) This is used to make a simple control deck for previous years robots, All robots get re-programmed for a 2 joystick control deck. Everything for the Control Deck is Ziptied to the wood above. Total weight est 5lbs 2) Alumnium , Diamond Plate and lexan - This is used for the current years robot everything gets velcroed / bolted down and is made for driver comfort. a piece of lexan covers the OI on top but allows access from all sides and wires are ziptied to some tubing welded onto the frame Total Weight est 10lbs |
| 2005 RadioShack® Innovation in Control Award! | dez250 | General Forum | 10 | 10-03-2005 21:29 |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 26-04-2004 21:27 |
| What do you wish you knew about the new control system? | Joe Ross | Control System | 2 | 09-01-2004 21:47 |
| Ok, how much is the control system worth? | archiver | 2001 | 6 | 23-06-2002 22:05 |
| more control options | smokescreen | Technical Discussion | 17 | 05-03-2002 15:41 |
