Go to Post To me, being in FIRST is the biggest learning experience anyone can have. I want to give that experience to everyone I can, be it now or thirty years down the line. - BandChick [more]
Unread 31-01-2005, 08:42
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
pic: Omni Idea
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 31-01-2005, 08:52
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: pic: Omni Idea
The way it's shown, I think it would come apart after the first side load. You can't take away the rim band and leave each spoke alone to withstand the torsional twist and bending it's going to get. But I was thinking maybe you could take a 1/16 metal/alum flat bar strip and wrap it around and loop it through those pvc's, then rivet them to the flats left on the rim band, it might hold up. But the pvc is too slippery alone. So I'd go get some rubber hose - whose ID was that of the PCV od. Then glue that on the PVC. You might have an OK omni. Or you could split the PVC, wrap it around the wheel rim without cutting the rim. Then glue on the hose again with the splits offset. I dunno, but applaud your thought process. G/L
www.179swampthing.org
Unread 31-01-2005, 09:34
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Re: pic: Omni Idea
If you can find away to not detsroy the outer ring of the wheel, you've got yourself one of the greatest (IMHO) concepts in FIRST! Perhaps you could cut a slot in the pvc, spead it around the wheel ring, then fasten the pvc back together (industrial staples, hot glue gun?). Once those are sealed again, just put some sort of grippy material on them and it could vey well work just as well as the fancier omniwheels out there.
Let us know how much play there are in the pvc pipes when they are on there. Do they slide between the spokes much? If they aren't extremely tight around the outside rim, do they "bounce" when they contact the ground?
Keep the ideas flowing!
Kev
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 31-01-2005, 11:01
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: pic: Omni Idea
I am thinking just use epoxy to attach the pvc back together. Hot glue and stuff like that is too rubbery and would catch when it tried to turn.
Unread 31-01-2005, 12:46
Sachiel7's Avatar
AKA: Shayne Helms
Re: pic: Omni Idea
Yeah It's still a work in progress.
Thanks for the feedback!
I think the idea of splitting the PVC rings should work good. Will try...
I'm going to test the idea on one of our old skyway wheels. I'll try to post a pic when I can!
Thanks!
-=Sachiel7=-
pic: A proposed drive train idea. Elgin Clock Extra Discussion 10 16-01-2005 23:29
BEST FUNDRAISING IDEA Macdaddy549 Fundraising 6 12-11-2004 15:11
Do u thinks its a good idea to start 2004 anim? Salik Syed 3D Animation and Competition 22 31-03-2003 00:48
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
Just an idea... Clark Gilbert CD Forum Support 1 06-11-2001 08:30
