Re: wiring?
I think you misunderstood his question. He meant to ask about wiring a four-wheel drive robot. The manual doesn't explain how to wire the four victors with the motors for a four-wheel drive configuration.
Re: wiring?
The wiring of the other speed controllers to the motors will be exactly similar to the one CIM shown connected on the electrical layout diagram. All you have to do is to connect 3 more 40 Amps (to the top circuit breaker panel area, the one that has large spaced slots) and connect them to 3 more speed controllers. All the ground wires for the speed controllers obviously come from the ground pin area of the circuit breaker. You then just connect the speed controllers to a separate CIM motor (therefore 4 CIM with 4 Speed Controllers)
Hope this helps |
Re: wiring?
if you search for it im sure youll find one, i even found one!!!
| LCD wiring to Program port | jgannon | Control System | 10 | 30-01-2005 23:28 |
| Neat & Organised Electric Wiring | thoughtful | Electrical | 30 | 13-12-2004 22:46 |
| Help wiring Line sensors | magical hands | Electrical | 1 | 18-02-2004 10:17 |
| Festo solenoid wiring? | computhief263 | Pneumatics | 1 | 15-02-2004 12:25 |
| Optical sensor wiring with the EDU Robot | Geoffrey4283 | Electrical | 3 | 15-01-2003 21:03 |
