Go to Post if we can't rely on experience and the human mind from time to time, then we're in trouble, aren't we? - Adam McLeod [more]
Unread 22-01-2005, 19:53
sgsdragons's Avatar
sgsdragons sgsdragons is offline
Team1595
AKA: Josh Lambeth
FRC #1595 (The Dragons)
Team Role: Driver
sgsdragons will become famous soon enoughsgsdragons will become famous soon enough
How to use multi-positioning?
Our team is trying to set up the pneumatics so we can use multi-positioning. We are having trouble. Can anyone please help us with this? Thanks
SGS Dragons
Unread 22-01-2005, 20:43
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
Re: How to use multi-positioning?
Pneumatic cylinders only have 2 positions. Either you can have them in or out. I know some teams have tested multipostioning, try a search.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 22-01-2005, 21:54
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
There were a number of good posts on this subject last year. You hook up a solenoid to your actuator as though you were going to just go with two positions. You then plumb the exhausts of this solenoid together and feed that combined exhaust to another solenoid. When you want to stop the actuator at a mid position position you close the second solenoid and that pressurizes the exahust side and stops the actuator in mid stroke.
Unread 22-01-2005, 21:57
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
100 of them
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 22-01-2005, 23:08
sgsdragons's Avatar
Team1595
AKA: Josh Lambeth
Team Role: Driver
Ok, Thanks everyone for the help. We got it to work and it seems to work fairly well. We are going to need to do a little work w/programing however. Thanks.
SGS Dragons
Unread 23-01-2005, 00:51
Matt Fultz's Avatar
Matt Fultz Matt Fultz is offline
Matt Fultz has a spectacular aura aboutMatt Fultz has a spectacular aura about
Chris Fultz and I sat down last year with a proposed idea on these Forums for multi-positioning, and made it work. There is a white paper here:
http://www.chiefdelphi.com/forums/pa...on=DESC&page=3
7th down on the page
If you have it figured out, this may not help much, but it really worked for us.
I am the son of a Woodie Flowers Award Winner
CyberBlue 234
"Don't confuse self worth with net worth"- Chris Fultz
Unread 23-01-2005, 04:05
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
So has anyone mad much luck using the magnetic switch things to make the cylinder stop somewhere along the length? Like we are looking at using such a system for autonomous stuff, and I would like to have two pre programmed stop points along the cylinder so we would essentially have four different positions we could put it in.
Unread 23-01-2005, 06:36
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
http://www.chiefdelphi.com/forums/papers.php?&categoryid=2&action=display&perpage=10 &sort=date&direction=DESC&page=3
That powerpoint depicts it rather well, although the second solenoid blocking off the outputs can be eliminated, thus simplifying the system. You can do this by using dual solenoid (three positon) valves in which the center position is blocked, then you can cut off the exhaust air from coming out by not enabling either valve. We did this successfully last year for two of our cylinders, our boom to hang and a caster that picked up one end of our robot to help us turn.
I have not tested using magnetic reed switches combined with multi-positioning, although it is possible - just expect a rather large margin of error. The reed switch would only sense it briefly before it passed by, so you would half to plan for this in programming. Also expect that it will be a little ways past (possibly even a couple inches) depending on your cylinder, pressure, and if you use flow controls.
If the cylinder wern't using flow controls and was moving too quickly then you might have issues with the reed switches never seeing the piston go by, but as long as you had it at a reasonable speed this shouldn't be a problem.
I wouldn't try and use reed switches combined with multi-positioning in order to operate something during autonomous because it wouldn't be all that accurate or dependable, instead I would say you would want to use actual three position cylinders.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 23-01-2005, 14:09
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
couldn't you use a needle valve with a servo to control the flow rate and their for control the length but limiting air going to it
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 27-01-2005, 15:46
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
As I said last year, 2 double acting solenoids, one to control the actual piston throw, make that solenoid's exaust common, as in put fittings on the EA and EB ports, T them together, then put it through a pilot controled check valve. On solenoid 2, plug either port A or B, and then control the check valve with the solenoid. It works in the most brilliant way. I've done it, and it works great. Either that, instead of staging a piston like this, just find where you want to stop the piston in mid throw, and get 2 pistons that equal the total throw you want, with one the place where you wish to stop, the other is the whole stroke.
ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 31-01-2005, 16:00
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Perhaps...but the flow control valves we have had in the past (and the ones this year look the same) have needed to go through like 5-10 rotations (screwed in/out) to go from full open to full close....
Granted you could hack the servo...or gear it up...but you would probably lose the high resolution that I'm guessing the was the draw to using a servo in the first place...
Hope this helps
-Bill
Autonomous Positioning SteveO Programming 9 16-01-2005 18:14
White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors CD47-Bot Extra Discussion 2 20-05-2004 21:22
banner sensor positioning and times bob1million Programming 4 16-02-2004 13:40
Wheel slippage w/ positioning systems Jay Lundy Electrical 3 12-12-2003 03:08
multi rotational potentiometers jdawson Electrical 8 27-01-2003 08:12
