Go to Post Ya know...they created the "RUMOR MILL" for a reason. - Andy Grady [more]
Unread 31-01-2005, 16:12
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
Red lights on Operator Interface
when we power up our robot we get red lights under the robot feedback section on the Operator Interface. right now we only have 4 speed controllers hooked up to the 4 cim motors. we are using the two pwm y-cables to hook up the speed contollers to the FRC Robot Controller in ports 1 and 2. all the lights on the speed controllers are orange, and when we go forwards they change green and red when when we go backwards. any ideas how we can fix this? thanx
Unread 31-01-2005, 18:08
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Red lights on Operator Interface
Does the robot work? If it does, its something from the default code (which IIRC, lets you calibrate your joysticks with it). Don't worry too much about it, red usually means they are going in reverse, green forward.
If you really want them gone, your programming team has to comment out/delete some stuff.
Specifically:
user_routines.c, somewhere around line 298..
if (user_display_mode == 0) /* User Mode is Off */
delete from there down until you see
/* (user_display_mode = 0) (User Mode is Off) */
And that should make those lights go off. It might be nice to use them to display motor outputs, but thats your choice
Unread 31-01-2005, 20:57
Vince lau's Avatar
FRC #4914
the lights on the operator interface stay red all time
Unread 31-01-2005, 21:12
Which version of the default code are you using? Version 2.2 uses the red and green PWM feedback LEDs to help in centering the joystick trim. Version 2.4 flashes the red LEDs each second when there is no communication with the CMUcam.
That's appropriate.
Nothing needs to be fixed. That's how the Victor indicator LEDs are supposed to work. They flash yellow/orange when there is no PWM signal, they go solid yellow/orange when the PWM signal is in the "neutral" deadband range around 127, they turn green at high forward control, and they turn red at high reverse control.
Unread 31-01-2005, 22:36
Vince lau's Avatar
FRC #4914
we don't have the camera, maybe thats why its flashing red. Thanks
Unread 01-02-2005, 00:11
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Sounds like you will just have to reload the version 2.2 if you dont plan to use the camera. But since its such a nice thing probably better to try to get the camera working.
-Mike
Yellow card / Red card usage at 2004 IRI Andy Baker Rules/Strategy 53 02-08-2004 00:35
VCU Finals Scores soap108 Regional Competitions 0 06-03-2004 15:19
Rotating Lights in the stands? psychoCHIPMUNKK Rules/Strategy 4 19-02-2004 23:47
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
is anyone wanting a lot of lights (decorative) on the robot? archiver 2001 5 24-06-2002 00:09
