Go to Post When Andy Baker holds an iPhone 4 in his left hand, the signal [i]increases[/i]. - Billfred [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia
Unread 31-01-2005, 19:29
Brian Lesser's Avatar
Brian Lesser Brian Lesser is offline
Bankai!
Brian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to behold
Send a message via AIM to Brian Lesser
Re: Doom 3 and joystick
1. Have you installed the proper sofware (if any) for the joystick?
2. Have you tried the USB ports yet?
Hi
Unread 31-01-2005, 23:22
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I have a new Saitek joystick installed in one of the USB ports. Software is correctly loaded.
I am able to play Counter Strike and Half-Life 2 with this set up.
Computer is only three months old.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 20-02-2005, 18:16
deees deees is offline
deees is an unknown quantity at this point
As far as I know, doom3 doesn't support joysticks. I'm not sure where in the options screen you were able to enable it. I'm running version 1.1, and don't see any reference to joysticks in the menu.
I use a mouse and joystick myself. The joystick is a belkin n45 modified for one-hand use.
I've relocated the right-side triggers to under the left-handle so I get about 15 buttons without removing my hand.
The software permits the assignment of keystrokes to axes/buttons so it works in doom3. You should be able to do the same with your Saitek.
The option to reverse the mouse axis is in OPTIONS, GAME OPTIONS, INVERT MOUSE, YES/NO.
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
