First of all i cant update with the master code and second when i load the defult code hex file the ifi says invalid hex file unable to download. can anyone help me?
Granite HIlls #1527 Bionic Battalion |
Re: HELP!!! the ifi loader is giving me errors
Could you be a little more specific about how you are attempting to load the updated Master Code?
i connect the serial cable to the rc and then connect the teather to the oi then i hit the programming button on the rc then i go to the computer and open the ifi loader then put it to port 3 and then verifythe device and it connects from there i should be able to open the hex file and download it to the rc but the ifi says that the hex file i opend is invalid
try recompiling(Project->Build All) the HEX file from MP-LAB,
and make sure that you have all of the settings set in Language Tool-set, and make sure that you have the right PIC-set. Last edited by AIBob : 31-01-2005 at 20:18. Reason: type |
im pretty sure i have everything setup correctly ill check
Anyway, when I subsequently tried to load the .HEX file to the RC, the IFI Loader made the same complaint about the file. By removing that flag, via Project->Build Options...->Project->MPLAB C18 tab, the IFI Loader stopped complaining. Note that even if you clear the flag by removing it in the Macro Definitions window, if you are using the alternative settings, you must clear the flag there. I hope this this solves your problem. Good luck! |
#7
Last edited by Anton : 03-02-2005 at 14:33. Reason: i saw that my answer didn't answer the question |
| Does the new IFI Loader work with the old Firmware? | gnormhurst | Programming | 2 | 17-01-2005 20:11 |
| Um... IFI Loader | Ryan M. | Programming | 3 | 14-01-2005 21:15 |
| White Paper Discuss: IFI Loader for Linux with compiling instructions | CD47-Bot | Extra Discussion | 1 | 09-02-2004 16:46 |
| IFI Loader Doc's | Raven_Writer | Programming | 0 | 21-01-2004 17:53 |
| Bug in IFI Loader | rwaliany | Programming | 2 | 06-01-2004 21:26 |
