Go to Post I would like to extend my deepest, most sincere thanks to the GDC, for bringing alliances to us in 1999. - Ken Patton [more]
Unread 31-01-2005, 20:07
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Exclamation HELP!!! the ifi loader is giving me errors
First of all i cant update with the master code and second when i load the defult code hex file the ifi says invalid hex file unable to download. can anyone help me?
Granite HIlls #1527
Bionic Battalion
Unread 31-01-2005, 20:11
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Re: HELP!!! the ifi loader is giving me errors
Could you be a little more specific about how you are attempting to load the updated Master Code?
Unread 31-01-2005, 20:16
AKA: Cameron Dennis
i connect the serial cable to the rc and then connect the teather to the oi then i hit the programming button on the rc then i go to the computer and open the ifi loader then put it to port 3 and then verifythe device and it connects from there i should be able to open the hex file and download it to the rc but the ifi says that the hex file i opend is invalid
Unread 31-01-2005, 20:18
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
try recompiling(Project->Build All) the HEX file from MP-LAB,
and make sure that you have all of the settings set in Language Tool-set, and make sure that you have the right PIC-set.
- from B B frank
Unread 31-01-2005, 20:20
AKA: Cameron Dennis
im pretty sure i have everything setup correctly ill check
Unread 03-02-2005, 11:48
Chet Urata Chet Urata is offline
Chet Urata is an unknown quantity at this point
We had a similar error message, although the problem could be different. Our problem was caused because I used the _SIMULATOR compiler flag when I was checking if we could use MPLAB to run the code in simulation mode (which didn't work due to a lack of support for the serial I/O).
Anyway, when I subsequently tried to load the .HEX file to the RC, the IFI Loader made the same complaint about the file. By removing that flag, via Project->Build Options...->Project->MPLAB C18 tab, the IFI Loader stopped complaining. Note that even if you clear the flag by removing it in the Macro Definitions window, if you are using the alternative settings, you must clear the flag there. I hope this this solves your problem. Good luck!
Unread 03-02-2005, 14:25
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
Maybe you didn;t download the master code- it's on the ifirobotics.com/rc.shtml site, with instructions included.
Last edited by Anton : 03-02-2005 at 14:33. Reason: i saw that my answer didn't answer the question
Does the new IFI Loader work with the old Firmware? gnormhurst Programming 2 17-01-2005 20:11
Um... IFI Loader Ryan M. Programming 3 14-01-2005 21:15
White Paper Discuss: IFI Loader for Linux with compiling instructions CD47-Bot Extra Discussion 1 09-02-2004 16:46
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
