Re: Keeping the Chuck on the mill
As others have indicated it it a very bad idea mill with end mills in a drill chuck. The drill taper is not designed to hold with a side load. It is designed to drill (up and down) so the forces press the drill chuck onto the taper when drilling. You can get a set of R8 collets very inexpensively from ENCO (www.use-enco.com).
6pc R8 collet set DD231-4606 currently on sale for $19.95 11pc R8 collet set DD231-4611 on sale for $36.95 23 pc R8 collet set DD231-4624 on sale for $77.95 The $20 6pc set should serve you well and be much safer than milling with a drill chuck. |
| Digital Caliper as a Digital Readout on Small Mill | sanddrag | Technical Discussion | 9 | 13-10-2005 22:51 |
| Mill Suggestions? | phrontist | General Forum | 29 | 27-02-2005 14:00 |
| CNC Mill Help | Rickertsen2 | Technical Discussion | 8 | 25-08-2004 00:59 |
| Haas CNC Mill Graph Function | P-Dog | Technical Discussion | 9 | 13-03-2004 23:45 |
| 1/2" #20 threads keyless chuck needed | Jeff Frangenber | Motors | 3 | 13-02-2004 07:54 |
