Go to Post Your team has a cave?!?!? OMG, how did you guys get that?!?! Do you have a cave sponsor? We tried talking to cave sponsors but none of them responded. You guys must be an elite team to have a cave. - marshall [more]
Unread 01-02-2005, 01:36
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Cheeseholing suggestions
Does anyone have experiance cheeseholing 2x2 1/8th wall Aluminum? I'm sure people have done this before and I was wondering if anyone had suggestions or recommendations on the most efficient way to cheesehole it. We're a little screwed in terms of weight at the moment. Thanks.
Alex
President
Team 1072 Harker Robotics
Unread 01-02-2005, 01:40
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Re: Cheeseholing suggestions
The lower and upper arm of 258's 2004 robot was 3"x3" aluminum with a .125" wall...
http://www.markrobot.com/gallery.php...ncoln%2F30.jpg
http://www.markrobot.com/gallery.php...ncoln%2F26.jpg
http://www.markrobot.com/gallery.php...ncoln%2F31.jpg
http://www.markrobot.com/gallery.php...ncoln%2F34.jpg
PM/IM/Reply if you have any questions.
-Bill
Unread 01-02-2005, 08:20
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
We usually have the students do it with a step drill for holes 1.0" or smaller or a hole saw for larger holes. It does keep them busy for quite a while though.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 01-02-2005, 10:10
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Cautious Encouragement
Just a few words of caution...
For the hole saw rookies:
Expect to get a hole LARGER than the hole saw is marked at.
How much larger depends on the condition of the hole saw (old and mangled = much larger hole)
Also...
Keep in mind the possible loads that these members will experience (use a healthy safety factor- depending on location, it could be very difficult to replace at Competition). Run some stress and strain calculations with the proposed reduced cross-sections before you start going completely crazy (2.75" hole in a 3" wide tube ) with the hole saw...
No one wants to have the piece that they spent hours swiss-cheesing break in half...
my two cents
-Bill
Unread 01-02-2005, 15:08
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Cautious Encouragement
Originally Posted by BillCloyes
Also...
my two cents
-Bill
If Alex1072 can provide a better picture of how the aluminum member will be used, then I can probably give a good idea of just how far you can take the speed holes. But I'd hate to give a number, say for a simply supported beam, and then find out you were actually cantilevering the load. They are different problems with different answers.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 01-02-2005, 15:24
AKA: Alex
We're using it as a vertical support. Actually you can see the 2x2 in one of the teasers i posted. The other places we want to cheese hole are at the base of our arm (cross bar), and as a vertical tower for cabling purposes.
Alex
President
Unread 01-02-2005, 18:46
Generally Useless
The moment generated by the arm needs to go into whatever is holding it up. You also need to consider side loads (like impacts with other robots) that can create torsion around the 2x2. I typically assume a 1/2g side load in addition to the normal gravity load.
Assume that the 2x2 is at the "back" of the robot and the arm swings up and down pointed towards the "front" If you knew it was only going to resist the moment from the arm and gravity, you could probably cut 1 1/2 inch diameter holes in the left and right faces of the tube and space them 2" apart without compromising the strength of the tube in the fore and aft direction. However, I have not investigated the effect of such holes on torsional strength and stiffness. The bolt on rails will also have some effect, but since I know little about them, I can't estimate how much.
"Who is John Galt?"
Unread 01-02-2005, 18:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Lasercutting or Waterjetting or CNC milling are the only real "professional grade" solutions. The only other alternative would be a hole saw but you will have lots of filing and sanding to do, it comes out ugly. Also, prepare to go through lots of hole saws.
Unread 01-02-2005, 22:06
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
Ideally, equilateral triangles water jetted, or cnc'd or whatever into the 2x2 would be great. Assuming you don't have these resources, I would suggest 1 inch holes every 2 inches with 1/2 inch holes every 2 inches in between the 1 inch holes, 1/2 an inch from the outside. Its difficult to picture from my description, so I've attached a model. Also, make sure you offset the sides by an inch so you make sure you have the most material possible at the edges while still removing the same amount of material.
If you going to drill one set of holes down the middle, MAKE SURE YOU OFFSET THEM. I've seen many teams that don't do this, and their just throwing strength away. See attached jpegs for more info. The pictures can explain it better than I can. Offsetting the holes doens't change the weight, but you conserve strength considerably when they are offset.
Sorry for any vagueness. PM me for more info
ID:	2871  Click image for larger version
ID:	2875  Click image for larger version
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 01-02-2005, 22:12
Retired -- 2006
I disagree with your theoretical "professional grade" statement (not that perfection is required on FIRST robots). Check those 2" holes in the pics I linked earlier (I can take other pictures tomorrow, if you're not convinced). All done with a single hole-saw, deburred by hand, and then sanded with fine sandpaper. It looked/looks great.
<edit>
Also note the offset holes, like Holtzman mentioned earlier.
</edit>
Unread 02-02-2005, 10:10
BillCloyes's Avatar
I agree completely... A hole saw used on a vertical mill (or even a good drill press with either a 2 axis bed, or really good marking/measuring and center punching) will produce a very good hole. (if you were that worried about it being a 2.000" hole, it wouldn't really be cheese hole...)
As for the wear on the hole saw itself....
* Generally speaking, hole saws are made to be run slowly (bigger diameter the slower spindle speed).
* The use of Cutting Fluid (not just oil (lubricant) or coolant) will quicken the process and also extend the life of the tooling.
-Bill
[ECDU]: Motto Suggestions Bharat Nain FIRST-related Organizations 13 19-07-2004 20:54
Suggestions about champs? Anne Shade Championship Event 25 21-04-2004 16:12
Fantasy FIRST suggestions for next year Joe Ross Fantasy FIRST 39 14-04-2004 01:13
Reputation Level suggestions Brandon Martus CD Forum Support 42 10-01-2004 08:58
