Go to Post Show me the mentor who has never built a bad robot and I'll show you either a new mentor, a liar, or Andy Baker. - Andrew Schreiber [more]
Unread 01-02-2005, 02:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Low-Rider Robots
I believe our ground clearance is around an inch. We would go either a little lower or a little higher (to drive in goals) but the ground clearance is dictated by our wheel size and frame design which is dictated by our gearbox output speed. We did some real world tests and we feel that on a flat playing field, the CG does not have to be quite as low as we thought to remain stable. So, an inch it is.
Unread 01-02-2005, 21:59
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
We have about 1.5" to 2" inches of ground clearance. Just enough to get over the goal bases. We're not sure if we'll need that clearence but i think its better safe than sorry. Of course for pushing you'll be pushing against something with a ground clearence of .25 or higher depending on how hard you push.
Team Website
Unread 01-02-2005, 23:02
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
Originally Posted by D.J. Fluck
I'd think you'd almost have to be a low rider for this game if you plan on stacking more then one tetra at a time or plan on stacking pretty high....unless you like getting tipped or can prove otherwise. I think we're planning on having less then 3" of clearance, but i am not 100% for sure.
Then again, I have no mechanical design ability....im sure someone will prove my statement wrong
Anybody have an anti-tip mechanism We are going to try and use the accelerometer to automatically deploy "wheelie bars" if we are tipping a certain angle. We want to use probably pretty big pistons for this though and were heavy as it is
Unread 04-02-2005, 04:13
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
Our robot's drivetrain and wheels were inspired by team 121's low-riding colson wheels. We also have 4" wheels, which puts our chassis at about .25 inches of clearance. The problem is that the chassis bolt heads stick down about another .125 inches, this means that we cannot clear the HDPE loading zones.
Team 121: do you guys have .25 counting those bolt heads?
currently we are running a two wheel drive. On the front we have 4" omniwheels and on the back we have the 8" skyway wheels that we lifted up to match the clearance of the omnis.
Does anyone have any thoughts on how this will perform? We're going to do our first carpet test of this drivetrain tomorrow. I'm planning on putting some pictures up soon.
Unread 04-02-2005, 04:18
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Yeah, our arm. Actually, it really depends on what drivetrain we want to pick (yes, I know its week 4, apparently we're building 3 different drives...). But if it's the kit bot, we have an anti tip mechanism which is essentially a set of outriggers powered by the window and van door motors.
And, about 2" of clearance -- it can be reduced though.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 04-02-2005, 12:00
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
We bought flathead bolts and countersunk all of the heads that were on the bottom of the chassis so they are flush with the bottom. This is pretty easy to do and will solve your problem.
Hope this helps!
Rob
P.S. your setup should work great if you are powering all four wheels, you will have to do testing to determine if there is enough traction to manuver with only 2 powered wheels (its probably fine though)
Unread 04-02-2005, 13:41
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
in 2003 our robot had wheelie bars that were spring loaded so when the bot started to move the wheels pulled a string that pulled a pin to release the bars, it was light weight easy to make and replace. And it saved our bot from tipping more times then i can count.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 04-02-2005, 18:51
#833 Team Captain
AKA: Ben Honey
Hope this helps!
Rob
Rob, you think it would be a good idea to power the omnis on the front? With so little traction, would it matter? I suppose they have high forward and backward traction, so it would be good to drive them for that reason. But it wouldn't help for turning.
I was watching your third episode of American Robot and saw that you guys have a whole lot of control even with high traction wheels on the front and back (and middle!). Maybe it would be better to just put non-omnis on the front and drive them?
I already made an Ace Hardware run and bought all the bolts I need, and a new countersyncing bit, for mounting our electronics. I didn't even consider that we could countersync those chassis bolts. Duh! Thanks for the wake up call.
Unread 04-02-2005, 21:56
Brandon Holley's Avatar
Team 11 is gonna be cruisin .25" off the ground this year. Our frame is also gonna be very effective in the anti-tipping ability. Our arm also has the ability to right the robot up, and we will most likely have a set of outriggers (wheelie bars)
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 04-02-2005, 22:29
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Well, here are my thoughts. Remember that these are just opinions based on how I like the robot to manuver. You have to decide if you want to be able to be a pusher or have high manuverability. It sounds like you are going for manuverability. I prefer to have a robot turn around its own center, and if you have 2 powered wheels at the back it will turn around the back end. I just think this makes it easier for the driver to control.
Now, if you add powered non-omni wheels on the front, you have to recall that the wheels will be sliding sideways when you turn, causing friction. This can be both good and bad. A good amount of friction will make the turns very controllable as the robot will fishtail less. Too much friction will make you turn slow and draw lots of current while doing so. You really want a trade off of thiese elements. There are many threads on these boards about drivetrain ideas, and 2 vs. 4 vs. 6 wheel drive. Many people have offered their experience and knowlege to those debates. I suggest searching for them and reading up on them. Rember that your drivetrain should be a function of what you want to do, so set some performance goals and then give it some thought.
Also remember to test out your machine at the full competition weight! Try it with your current configuration, you might find that you like it alot and want to keep it.
Im glad the countersinking helped...
Best of luck, and feel free to PM me or some of the "much more knowlegable than me" people on the boards if you have any further questions!
Rob
Unread 04-02-2005, 23:15
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by MORT~11
Just a quick tip on the .25 " ground clearance....the loading zones are .25" HDPE
does anyone know how the HDPE is attached to the field? is it velcroed to the carpet, and if so, how does this affect the height of the HDPE? (i.e. will the velcro add 1/8" to the height, making the loding zone .375")
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 04-02-2005, 23:21
cadman2k5 cadman2k5 is offline
AKA: steve lami
#0637 (Horsepower)
Team Role: Student
cadman2k5 is on a distinguished road
Send a message via AIM to cadman2k5
yea Team 637 knows what it feels like to flip... NOT FUN. were goin low too.. not a quarter inch... but low.
http://www.njfirst.org/galleries.htm
check out the upside down Marotta logo pic
Unread 04-02-2005, 23:32
Iain McLeod's Avatar
Iain McLeod Iain McLeod is offline
#0358 (Robotic Eagles)
Team Role: Scout
Iain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of light
358 used to be .25'' but now we're about an inch.
I was really worried about flipping and crushing tetras this year too... everyone tells me that i'm exaggerating the danger, but i still vividly remember riding up onto balls many many times both last year and three years ago.
"The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair." -Douglas Adams
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
Robots doing origami! RoboMom Math and Science 4 24-10-2004 19:42
Robots Doing the Dirty Work! Brandon Martus Announcements 2 23-06-2004 12:31
Robots compete in first match (FitN) Clark Gilbert FIRST In the News... 0 24-03-2004 18:11
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
