Go to Post I'll not deprive you of the practice in reading the manual; you'll need it if you want to be an effective part of an FRC team. - Alan Anderson [more]
Unread 01-02-2005, 09:43
top dog's Avatar
top dog top dog is offline
Steve Sedlock
AKA: Steve Sedlock
FRC #1386 (Trobots)
top dog is an unknown quantity at this point
Send a message via AIM to top dog Send a message via Yahoo to top dog
Re: Screw drive motor
Originally Posted by Jeff Waegelin
You should be perfectly fine. Check the "Parts Use Flowchart" in "The Robot" section of the FIRST manual to be sure, but I see no problem with using that part.
Thanks a TON!
3 motor drive train nuggetsyl Motors 25 04-02-2005 00:34
DC motor design project Ian Mackenzie Motors 0 29-01-2005 13:30
Motor for Flexi Drive NateBot16 Inventor 0 24-02-2004 10:10
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
