Go to Post We have not always been a winning team but we have always tried to be a quality team. - WynS [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 01-02-2005, 11:11
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
CMU Cam servo jitter
When I hooked our CMUCam2 up to my PC for testing, both the pan and tilt servos "jittered" constantly. Kind of like they couldn't decide on what the exact center position was and were constantly switching between two positions.
I am using an external wall-wart type supply that supplies 12V and 500mah. The jumper for "use internal power to servos" is on.
Is anybody else experiencing this? In RC airplanes we will occasionally see jitter like this when using a fully charged 6.0v battery and it will continue until the voltage has dropped off a little, but I am assuming that power for the servos in this case is regulated to 5v, so it should not be an issue.
Thanks,
Adam
Unread 01-02-2005, 13:58
Obi's Avatar
Obi Obi is offline
Obi is an unknown quantity at this point
Re: CMU Cam servo jitter
Yes, we are experiencing that also. I believe that it is from the servo trying to return to the position you tell it to. How is it mounted to your test robot? We have it on an old robot with tape, and since that isn't as sturdy, it gives a little. Thus, the weight of the camera moves the servo around more than it wants, and it continues to over-correct. We can stop it from jittering by holding it in place.
[hr]
Southold Robotics Team #870 (RICE)
Unread 01-02-2005, 14:21
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Thanks,
Adam
We saw this jitter too when we powered it directly from the 12V breakout on the robot, but realized quickly that you're not supposed to do that unless you switch the "Servo Power" jumper to "External" - and then power the servos directly from a 7.2V source.
Chances are you're giving your servos 12V of power, like we were, and it's probably not a good idea to keep doing that. They like 7.2V much better.
I would recommend powering your camera right from a PWM output of the robot controller. Just pick one that isn't going to be used, and steal the power leads from it =).
-SlimBoJones...
Unread 01-02-2005, 14:42
Obi,
The servos aren't even mounted. Just sitting on the desk.
SlimBoJones,
You confirmed that we are seeing the same thing we see in the RC airplane world, servos don't like too much voltage. I will try a 7.2v source as the controller and I are in different locations currently so I can't use a PWM output (although that is what we will do eventually).
Thanks,
Adam
The *BIG* CMU Howto pi_guy578 Programming 17 21-12-2005 13:24
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
Tracking beacon without servo Paul Marshall Technical Discussion 17 10-02-2004 20:58
servo problems lpramo55 Programming 5 20-01-2004 22:23
