Go to Post Don't rely on the field staff to get every ball to work with your machine....engineer a robot that makes the change not matter. - PayneTrain [more]
Unread 01-02-2005, 12:07
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
How to take apart anderson connectors
Due to my poor planning, the electrical board is way to far from the battery moun to reach with the stock wire lengths. We have plenty of spare connectors, but i dont want to waste them. Also, since there is no easy/ reliable way to soldier the 6AWG wire i am running out of options. How do you take the anderson power connectors apart, so we can re attach a longer section.
Thanks
Marcus
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 01-02-2005, 12:09
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: How to take apart anderson connectors
http://www.powerwerx.com/product.asp...854&CtgID=1682
hope this helps...
Unread 01-02-2005, 12:45
You can use a screwdriver.
http://www.chiefdelphi.com/forums/sh...2&postcount=23
Unread 01-02-2005, 12:48
Electrical Engineer
Rookie Year: 1995
Marcus,
Unless you have the correct crimp tool for an Anderson connector, do not do this!
I am assuming that you have no "special" tools: Go to your local Lowes or Home Depot and get a wire nut sized for 2 * 6AWG and extend the wires that way.
Regards,
Mike Betts
As easy as 355/113...
Unread 01-02-2005, 14:45
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Originally Posted by Mike Betts
Marcus,
Regards,
Wire nuts are not something i would recommend using. Powerwerx sells contacts for the SB50's that do not require a special crimper (you can use the standard crimper that used to come in the kit a few years ago). The anderson contacts that come on the 6 ga wires from the kits require a special roll crimper. It would be far better to crimp a ring terminal on the two wires you need to connect, and then put a bolt through it and heatshrink them than using a wire nut. Also, with a good enough soldering iron you should be able to solder the connection. All our 6 ga connections are soldered, using a team member's metcal iron.
Unread 01-02-2005, 19:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Splicing in new wire, joining two ring terminals by bolt, or using wire nuts is a very low quality way of doing this and I would not recommend it. Also, the special crimper is not required for making the conection. Put the contact in a vise (lightly, just enought to hold) and then heat it up with a torch, (we have used a full size propane torch, but a butane pencil torch may work.) Then fill the "cup" with solder about 1/3 of the way. Then "tin" your wire with solder. Then heat up the "cup" again and drop the wire in, and feed in more solder until it just is about to overflow. This works great if it is done right. Just don't clamp the vise on the contact and don't het it up so much the contact surface gets burned.
Unread 01-02-2005, 23:09
Marcus,
If you go here...
http://www.powerwerx.com/techdata/assembly-anderson.pdf
you will find all the data you need for these connectors including how to disassemble and solder. Although all of the splice methods outlined above work they introduce one more failure point in your robot. Since this is primary wiring, I recommend you remake the cable and connector with the lengths you need. We remade some just last night using the 5900 high detent contact. One of our ratchet style crimp tools did a nice job on crimping the body around the #6 wire which we followed with a solder job using a large tip 45 watt iron. Remember that a good soldered connection is one that starts as a good mechanical connection.
You can also check out the family brochure at http://www.powerwerx.com/techdata/SB50-family.pdf
Unread 03-02-2005, 08:53
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Originally Posted by Mark McLeod
Just to explain better (since I did this 3 times to put them on our battery connectors) and I found it very hard to push in if you just soldered on top of the connector.
You get two people and a small screwdriver. One person goes to the front end and pushes the pin up off where it is, the other pulls out on the wire. It should pop out pretty easily. Then what we did was cut the wire as close as we could and drilled out the copper wire that was left within the clip (we use a small bit and afterwards the rest just fell out). We then drove a small flat head screw driver between the (now empty) clip to widen it a little bit. We then stripped a 6 gauge wire pushed it into the empty, widened clip (not quite as easy as it sounds). Then we crimped the clip (more of squeezed it with a pair of pliers) and soldered the wire to the connector. Then just push the connector back in and you'll feel it pop in. Now just do the same thing with the other side and you're done.
If you have any questions or I didn't explain myself, feel free to ask.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Restricted to the Anderson Connectors in the Kit? sanddrag Electrical 15 20-01-2005 11:36
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
